E46 (1999 - 2006)
Old 01-25-2013, 07:30 PM
NinetyNine323i NinetyNine323i is offline
Mein Auto: 99' 323i
18" wheels on 323i?
Hey guys, im looking into getting some Beyern multi wheels for my 99 323....was wondering if 18" wheels all aound will work on my car with any mods?? I really dont want it to rub at all, but i do want 90% of my wheel well gone..any suggestions/input?
Old 01-25-2013, 07:44 PM
anton2718 anton2718 is offline
Mein Auto: 01 325i
they'll fit
Old 01-25-2013, 07:45 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
It all depends on choosing the right combination of wheels & tires for your particular application. Read the E46 Wiki, there`s a lot of good wheel info posted by many of the members here.
Do you now what the terms "offset" and "hub centerbore diameter" mean ? They are the critical specs in determining what will or won`t work on yor car.
Avoid problems by educating yourself *before* buying anything. If you`re in doubt about something, we will help guide you along....
The road goes ever onward....
(R.I.P. Jever)
Old 01-25-2013, 08:11 PM
Mein Auto: 01 325i
hah yep...offset should be upper 30 to lower 40 and since you don't want any rubbing id go with a max of 245/40/18 tires all around, with 255/35 your offset needs to be perfect for no rubbing and in some cases it'll still rub
Old 01-26-2013, 10:36 PM
Mein Auto: 99' 323i
Awesome thanks alot guys....sounds like 18"s are the ones....should i just do normal 18's all around or should i do a little wider in the rear? would that look any better?
Old 01-27-2013, 07:40 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Think carefully about this. Too much wheel, and not enough motor IMHO. Performance and ride quality will suffer. See if you can find the same wheels in 17". You will be much happier. I would also suggest a square setup. This means all wheels are the same size.
Old 01-28-2013, 05:48 PM
Mein Auto: 99' 323i
yeah the wheels deff come in 17's....you think that would be a better situtation? im looking to keep my motor damn near stock just want it to look a little better. if i do the 17s should i lower it or leave it? sorry with the questions guys this is just my first bimma and i want it to look dope lol. thanks guys!
Old 01-28-2013, 10:35 PM
SJBimmer's Avatar
My car looks great withe the original 17" wheels. You only Have 170hp (I only have 184) and you will lose a lot of performance if you go larger. Our cars are slow to begin with, so you don't want it even slower. Plus if you hit any potholes, you most likely will get a flat with less sidewall. Plus 17" tires are cheaper. Nothing worse than looking fast when you are not. Remember, the heavier the wheel, the more unsprung weight, which is bad.
Old 01-28-2013, 10:45 PM
heztheone heztheone is offline
Mein Auto: ///M
dafuk is a bimma
anyways, if you want to make ur ride look nicer, 18'' would do just that, either way u can forget about having a performance vehicle, with 15'' or 18'' so what the heck, i say go for it
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
