Old 12-14-2010, 08:18 PM
jaxbmw84 jaxbmw84 is offline
Mein Auto: 2006 325i
2006 325i Push Start Button Question Help PLEASE
Hi guys,
Is the push start button light supposed to stay on after the car is off and the key is out? If not how do i fix this problem? Thanks!
Old 12-15-2010, 06:33 AM
puff3456 puff3456 is offline
Mein Auto: 2006 330i 6MT
Mine stays lit for a period of time after the key is out, probably until the car goes to "sleep," I say that it's normal. Although the first time I noticed it I thought there was something wrong as well. If you leave the car and come back in something like 15-20 minutes (maybe less) you'll see that it is no longer lit.
Old 12-15-2010, 09:15 AM
guerilla twang's Avatar
guerilla twang guerilla twang is offline
I do my crosswords in pen
Mein Auto: OEM+ 330i
^truth.
Old 12-15-2010, 09:18 AM
///M-Furby's Avatar
///M-Furby ///M-Furby is offline
IntarWeb Stalker
Mein Auto: 2016 M3 SO ZCP
Yup. Turn it off, leave your car. Come back 30 minutes later. If it's still on there is a problem. One thing to note even if it is still on your battary will not be drained (from the light itself). The cars have a parking feature where you leave one side of your lights on for up to 2-3 days. It's a carry-over from Europe where small, dark streets, require you leave your lights on when parking. So they make these cars/battaries powerful enough to manage that.
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS |
"Booberry" ED 2013 335xi | Returned
"Boo" CPO 2006 330xi | Sold
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 12-15-2010, 09:20 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
if you have CA, the car will wake up with the key near. so if you're doing the 30 min sleep test, leave the key away from the car when u go back to check
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
///M-Furby's Avatar
IntarWeb Stalker
Damn you CA for breaking my QA...DAMN YOU!!!!!
My Drive Style
Because I can.
I agree with furby
Old 12-15-2010, 09:52 AM
rtgirard's Avatar
rtgirard rtgirard is offline
1-5-3-6-2-4
Mein Auto: 2013 335xi
on a related note... if you don't have CA, you can remove the key after shutting off the engine, yet still start the engine again without re-inserting the key. you can only do this once, then when the engine is shut off again it won't restart until the key is replaced. someone else described this feature much better in an old thread... i'm too lazy to find it now.
F30 335xi - Ordered on 9/5/2012... Delivered 10/29/2012
Alpine|Coral|ZSL|ZPP|Nav|ZDH|SportAuto
BMWCCA# 457109
Old 12-16-2010, 08:35 PM
Ericcorp Ericcorp is offline
Wait. How do you make this happen? When I first got my 325 this would happen sometimes. I thought it was a glitch
Edit: I'm referring to the European half light parking. I didn't know how to quote on the iPhone app, sorry.
Old 12-17-2010, 09:52 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
Mein Auto: '07 328iT.'13 Boxster
On my '07, the manual says to move the headlight stalk up or down (as opposed to in or out for high beams). It also warns against possible battery discharge. See "Roadside Parking Lamps".
Tom
Old 04-27-2011, 12:34 PM
06-RiC 06-RiC is offline
Mein Auto: Bronx
Exclamation Sleep Disorder
My 330xi has the same issue and everytime that i leave it anywere when i come back its dead ... i give it a jump park it some where and when i return its dead again...
so i deffinetly wouldnt say that its NORMAL for the light to stay on and it most certinly dose eventually have the power to drain ur battery
Old 04-27-2011, 12:44 PM
no, you have another electrical issue.
an led cannot drain a battery that much.
on an 06 330i, if the battery has never been replaced its probably shot at this point, or there's some other electronics draining the battery (aftermarket, etc)
Old 01-08-2017, 01:37 PM
alex308 alex308 is offline
Mein Auto: 2006 BMW 325i
Same thing.
I never had this happen. I reset some fuses now the cars push start button stays on. I checked in the morning the light was still on. Now there is a problem.
