Old 01-26-2013, 08:42 AM
dsukia dsukia is offline
Mein Auto: 750i
brake and drive control systems malfunction. Parking break without emergency braking
Hello everyone,
I am getting this error,
brake and drive control systems malfunction. Parking break without emergency braking function
Took car to dealer and they said it was the DSC Brake pressure sensor and did change it but I am still getting these errors. Turning off the car and turning it back on makes the error go away.
No other errors or codes.
anyone have any insight?
Old 01-26-2013, 11:54 AM
Hutch911 Hutch911 is offline
Mein Auto: BMW 730Li
I had similar problem. The precharge pump quit, causing the abs to malfunction. A visit to an indy who recalibrated the system for 30 solved it.
Old 01-26-2013, 10:35 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Originally Posted by dsukia View Post
Hello everyone,
have you checked what fault codes you have ???
Old 01-27-2013, 04:05 AM
Mein Auto: 750i
The dealer did, only thing they saw was dsc break pressure sensor fault which they changed
No other codes
Old 01-27-2013, 12:36 PM
PAPER's Avatar
CRISP & CLEAN
I doubt that was the only fault .
If you want to drive down I can check
your faults with INPA
Sent from my GT-N7000 using Bimmer App
Old 01-27-2013, 12:49 PM
Mein Auto: 750i
Paper,
Thanks, where are you located?
I am all the way in Ventura County but do drive downtown every couple of weeks.
Old 01-27-2013, 01:31 PM
PAPER's Avatar
CRISP & CLEAN
PM sent
Old 01-28-2013, 10:23 AM
Mein Auto: 750i
Paper, thanks
Old 01-29-2013, 04:22 PM
Mein Auto: 750i
Dealer gave me free reading and a nice fantasy estimate. They are now saying its the DSC Control module that is bad. I really think its my battery since all these issues started when my wife ran the battery low one night.
Anyway anyone done this, easy to do? requires re-programming or is it just install and go?
Old 01-29-2013, 05:14 PM
Mein Auto: 750i
They are saying its a multi failure and last time they x now they get y. At the dealer now.
Asked them to give me codes for both visits according to them last one is archived (a day ago archived ?) and they will send later via email
Current code is b3450-65e00
2.93 bar.
He says that should be below 2
Anyone have good experience with indi repair shop near me please let me know. I am in Ventura Camarillo
Honestly don't think it's the module.
I should mention, I have Front Break coming up in 1000 miles.
Old 01-30-2013, 05:40 PM
stevest stevest is offline
Mein Auto: 2005 745li
Any word on what the problem was?
Sent from my GT-P3113 using Bimmer App
Old 01-30-2013, 06:03 PM
Mein Auto: 750i
Still have not had time to deal with it. It is not a daily driver.
When I get it figured out will update the ticket.
Old 02-26-2013, 01:21 AM
Mein Auto: 750i
Ended up changing the dsc control module. So far no errors.
Dealer gave me credit for the dsc pressure sensor change.
They may have done other work on the car as I see things like abs sensor being replaced on the work report but I was only charged for module.
So far so good.
Did break job on it, now left front angel eye is out. Ordered m-tech v3's will install soon.
But breaks seem fine now. I don't think control module failure is common from what I understand. Will update if I get the error again.
