Old 01-26-2013, 10:12 AM
Robcromar Robcromar is offline
Mein Auto: 2010 328i
New BMW owner - this stuff normal?
I am in the second month of owning a CPO 2010 328i sedan. 42K miles. This is my first BMW after many years of Honda and Toyota ownership. I realize it's a very different type of car, so I am still learning! I love the car, it looks and drives great - fast, sure handling. All systems on the car report OK -- But there are little things I wonder about -
1. The car has been back to the dealer once and will be going back again because the rubber moulding that runs along the bottom of the rear window - seals between the rear window and trunk lid - is separating from the window, leaving a large gap. Dealer attempted to repair, separation is now worse -- common complaint?
2. When decelerating to a stop, the car sometimes abruptly and very noticeably downshifts hard into a lower gear (2nd??). I also feel when pulling away from a stop, there is hesitation and a hard shift (a late downshift into first gear??) when i push the accelerator. I tried faster starts, slower starts - it seems the car pulls away smoother if i make a fast start - is this normal?? I see posts about hard 1 - 2 and 2 - 1 shifting, but it appears to affect earlier model 7 series... all that said, i was given a brand new 2013 3281 as a service loaner and it seemed to shift in a pattern similar to mine when put in "Sport" mode ... so is mine shifting as it should?? All other shifts are very smooth and appropriate, so i want to think the transmission is mechanically sound, might have a programming issue?? The hesitation off the line has me a little concerned...
Old 01-26-2013, 10:28 AM
sunny5280 sunny5280 is offline
Mein Auto: 2011 X5-M
This is the first time I've read about this particular issue. I'm sure others have experienced it but it doesn't seem common enough to have warranted a mention on this forum.
This seems unusual to me. I haven't read many complaints of hard transmission shifts with the 3-series. I have read quite a number for the E53 X5 series. Enough to give me the impression there's an issue with the design of the transmission. Given this I would have it checked out. BMW will probably state they couldn't repeat the issue or that it is normal behavior. But from what you've describe I believe it is abnormal.
Old 01-26-2013, 03:22 PM
oldgoalie oldgoalie is offline
Mein Auto: 2011 335d
1. The car has been back to the dealer once and will be going back again because the rubber moulding that runs along the bottom of the rear window - seals between the rear window and trunk lid - is separating from the window, leaving a large gap. Dealer attempted to repair, separation is now worse -- common complaint?.
I had this happen. They tried at first to just add more adhesive in there and it came out worse in a week or so. The next time they replaced the trim and it has been fine ever since. Mine was pretty new when this happened.
Old 01-26-2013, 05:06 PM
DSXMachina's Avatar
Bimmerdex 7.4!
I believe both issues have been discussed, especially the second extensively. Try a 'Search'.
Old 01-27-2013, 05:32 AM
Cyb3r H3x's Avatar
Cyb3r H3x Cyb3r H3x is offline
BMW CCA Member
Mein Auto: 14' i3 Rex Mega LG
OP try a search for the Adaptive Auto Transmission Reset Procedure. Here is a link: http://www.bimmerfest.com/forums/sho...d.php?t=261285
Old 01-27-2013, 07:29 AM
THANK YOU - very helpful. Helpful for the reset procedure, I'll try it when I get home next week, and for the redirect to very useful posts. Helps me to see what to look for when searching! Thanks again.
Old 02-03-2013, 08:48 AM
AMAZING! I did the *very simple* procedure last night and the car drives even better!! The hesitation is GONE, shifts are smooth and as expected, including down shifts! I see in the other threads the benefits may be only temporary, so we'll see!
THANK YOU!!!
Old 02-04-2013, 12:04 PM
Cyb3r H3x's Avatar
BMW CCA Member
THANK YOU!!!
Hope it works out for you in the long run. Keep us posted.
