Old 01-26-2013, 11:59 AM
Mike Swing's Avatar
Mike Swing Mike Swing is offline
Mike Swing
Send a message via AIM to Mike Swing
Mein Auto: 2000 Z3M 2007 530i
Spark plugs for N52 engine
Quick question or advice from you guys. Idrive is telling me to replace my plugs soon. Is there a difference in spark plugs? Should I go with oem spark plugs & go to the dealer? Maybe go to a trusted Indy shop? Last, what has been your experience with oem plugs versus aftermarket? Thanks in advance guys.
Mike Swing
Old 01-26-2013, 12:02 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
OEM's are the safest bet. Personally I don't believe wasting money on all of the latest spark plug hype is worth it, whatever that is right now.
Old 01-26-2013, 12:29 PM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i, F13 M6
OEM brands like BOSCH or NGK will be sufficient
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 01-26-2013, 01:26 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
I stuck with oem. I changed mine at around 102,000 along with coils. No issues to report.
Old 01-26-2013, 02:27 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
This!
Old 01-26-2013, 02:38 PM
Rahulk Rahulk is offline
Mein Auto: E53 N62; E90 N52
The oem's cost $27 each, you can get the exact same Bosch one's for $7 each... It's not to tough to change them, you just need to off the cabin filter fixture... The Bosch part number is, ugh forgot the name but you can find the part number on tons of sites... Autozone carries them special order... As for coils, they are $30 each no point in replacing them till one fails, and when it fails you just have a rough idle, and SES light, it's intermittent.... Change all 6, when the first one fails... Usually around 150k
The only different between the spark plugs is that the OEM says bmw on it and the Bosch says Bosch on it, they all are made by Bosch - platinum-iradium
Old 01-26-2013, 03:24 PM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
I changed my plugs almost a year ago and noticed this too. Plugs are identical other than the print on them.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 01-26-2013, 06:14 PM
Mein Auto: A Car
Many people confuse the term OEM with OE.
OEM means original equipment manufacturer which are the companies that manufactures the parts and then re-brand the product packaging for other companies. OE means original equipment which means . . . i don't think i need to say more.
OEM's spark plugs are usually from $6-$10 and OE spark plugs are for $25+.
Old 01-28-2013, 09:44 AM
Mike Swing's Avatar
Mike Swing
Thanks for all the info guys. I'm gonna check the price difference from the dealership to a local shop.
Mike Swing
Old 01-28-2013, 02:54 PM
Mein Auto: A Car
BTW, i think the OEM Manufacturer for the N52 engine is NGK. (Based on pictures i've seen online)
Old 03-20-2013, 06:34 AM
Mike Swing's Avatar
Mike Swing
BMW dealership wants about $450 to change out spark plugs. Is that all they do? Is anything else done during a spark plug change on our cars? Is this considered a 'tune up'?
Mike Swing
Old 03-20-2013, 06:37 AM
bimmerzone's Avatar
Supporting Vendor
wow, that is a sick price....
nope, change the plugs, wash your hands and thats about it.
Old 03-20-2013, 07:12 AM
DIY'er
$450 is absurd.
Old 03-20-2013, 07:19 AM
boramkiv's Avatar
Propellers Up Front
That's not surprising coming from a dealership.
Although it can be done for much cheaper at an Indy, or even cheaper yourself.
Old 03-20-2013, 07:34 AM
bimmerzone's Avatar
Supporting Vendor
The NGK is $42.95 for a 6 pack
http://www.bimmerzone.com/product/NGK-BKR6EQUP.html
DIY on an Inline 6 30 mins (1 hour max)
Take your significant other out for a SUPER dinner and you will still have change
Old 03-20-2013, 09:07 AM
txag_530i's Avatar
txag_530i txag_530i is offline
Mein Auto: 2006 530i
You'll want a locking extension to use with the spark plug socket, or use one like the Gearwrench 80546.
Here's a link to a DIY.
Old 03-20-2013, 09:28 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
You may need thin wall socket (regular spark-plug socket is too beefy to get into the holes). Hate to see you remove the cabin-air-filter housing to find out you need this thin-wall socket. Better save than sorry.
spark plugs replacement
