Old 12-11-2016, 07:49 AM
Kingtetley Kingtetley is offline
Mein Auto: Bmw e39 520i
Engine wobble
Hi I'm pretty sure my engine/transmission mounts are going to need replacing but i wanted a second opinion, when my car is out of gear and i rev, the engine feels like its wobbling but only as the revs are building.
If i get the revs to say 3000 and hold it there the wobble fades slightly but is still noticeable, the clutch meeds replacing for sure as i get a vibration sometimes when pulling off could this affect the car when out of gear?
Its an 520i 2002 manual
Thanks in advance for any help or replies xxx
Old 12-11-2016, 08:12 AM
528iAut 528iAut is offline
Mein Auto: 528i
Mine is just the opposite, at cold idle I feel a little vibration in the cabin, goes away when acceleratur is pushed.
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Oxford Green.
Old 12-11-2016, 10:35 AM
Wgosma's Avatar
Wgosma Wgosma is online now
Mein Auto: 2000 528i M-sport 5spd
Pop the hood, find another person to observe the motor for any movement as you Rev the motor; maybe even secure the parking brake, give a bit of gas and let clutch engage with trans in reverse and see if observer can see motor movement- if so, that's pretty clear sign mounts are at fault.
Bill / Oceanside, CA
00 528i - 5 spd M-Sport
Old 12-11-2016, 10:40 AM
Wgosma's Avatar
Oops; guess you Euro folks need to pop the bonnet to look at the motor
Old 12-11-2016, 01:23 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The front engine mounts are liquid-filled. They don't last forever. I replaced mine at 153k. They showed signs of leakage.
Old 12-11-2016, 03:43 PM
MKJS MKJS is offline
Mein Auto: '99 540iA
Have read many people finding their trans mounts worn out also, give those a looks see too while you're under there.
Jim
Old 12-11-2016, 07:31 PM
Barracuz Barracuz is offline
Nothing to read here...
Mein Auto: 2001 525i 5 spd
Wobbling? Wouldn't failed mount simply give a single movement when accelerating and decelerating?
But as others have mentioned check engine, trans, and even surframe mounts. And while under there inspect the guibo, center support bearing and the rear cv joint.
The Crappitto-Stockitto-Baseito
**Word of Caution**
My knowledge is limited. Anything I write in my posts may or may not be accurate. To be honest I think its all crap.
