Old 01-26-2013, 01:39 PM
Rev_Dynamics Rev_Dynamics is offline
Revdynamics.net
Mein Auto: Multiple...
Coolant leak out of different weep hole.
I have some coolant coming out of the water pump weep hole sporadically and leaving a small puddle when parked. Takes a month or so for the coolant low light to come on.
I know the timing cover weep hole is a sure sign of a bad coolant pipe but any ideas on the water pumps hole?
Old 02-17-2013, 10:18 AM
Revdynamics.net
Any one have any idea about this hole? I believe its a one way bleed off but not sure. I can pressurize the cooling system with compressed air through it. Doesn't leak when I squeeze the radiator hose but believe it is while driving or when cooling down.
Old 02-17-2013, 12:26 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
From what I've heard it's a failing water pump. I'm not 100% sure. Maybe someone else can chime in
Old 02-17-2013, 05:13 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Wp - I have an OEM one that is in perfect shape, has 46k on it, was installed by dealer.. I thought it was bad because of a noise that everyone on here said was pump ended up being the sec. air hose.. the bearing is in perfect condition, as is the rest. You can have for $40.. is not hard at all to install.
Old 02-18-2013, 09:33 AM
Revdynamics.net
Thanks for the response guys. So that's a sure sign of a bad water pump? If so I would be interested in yours. How many miles are on it?
Old 02-18-2013, 09:36 AM
Revdynamics.net
Just found this for anyone in the future. http://www.flowkoolerwaterpumps.com/..._failures.html
Wp is definitely the problem. Very glad its not the coolant pipe. Halleluiah
Old 02-19-2013, 05:08 AM
wucrew wucrew is offline
Mein Auto: 2011 E70 X5
Had the same problem, Ordered a new WP just waiting for it in the mail.
http://www.bimmerfest.com/forums/sho...540&highlight=
Old 04-26-2013, 01:58 PM
Louiscalderon Louiscalderon is offline
Mein Auto: 745li
Weep hole issue
I have the same issue right now!!! I got freaked out because I called it in to my b,w mechanic and he said that is the "other weep hole" issue.....thank God it looks like a water pump issue. I just changed the alternator, battery, coolant hoses, expansion tank, radiator. Should had changed the water pump! So it's a water pump failure?
Old 04-26-2013, 02:00 PM
Mein Auto: 745li
Do you still have the water pump, I will buy it!
Old 04-26-2013, 02:54 PM
Revdynamics.net
Bummer! I just ordered a new water pump and thermostat so we will see. It will be in next week and I will update on here. I have gotten a stuck thermostat code twice.
