Old 01-26-2013, 06:35 PM
beevbeer1 beevbeer1 is offline
Mein Auto: 528i
99 540i sport ringing sound from transmission
Last Friday i heard a loud ringing sound from my 1999 540ia sport. I thought it was a bearing then while under the car thought i had pin pointed it to catalytic converter break down as it sounded like a marble rattling around in the exhaust pipe. The noise changed with RPM and seemed to go away when braking. I took her to an exhaust shop and the sound seemed to be coming from the front of the transmission housing.
I took her to my mechanic who removed the inspection panel at the front of the bell housing and the sound seemed to be coming from inside. He says it sounds like a bolt came loose from the flywheel and is rattling around in there. I do not see how this is possible.
He also said the best course of action would be to remove the starter to see if something hasn't happened where the starter is rubbing on the flywheel causing the sound which is loudest when the car is accelerating and almost quiet under braking.
I have scoured all forums and have not found a single instance like this.
Any other thoughts would be greatly appreciated.
Old 01-26-2013, 10:59 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
I'm not aware of any "inspection panel at the front of the bell housing." Post a video of the sound.
Old 01-27-2013, 08:12 AM
Mein Auto: 528i
unless someone took a holesaw and drilled a 2 inch hole on the front then there is a removable plastic cap that goes over it. Will try to upload video tomorrow.
Old 01-27-2013, 07:31 PM
jetpilot10's Avatar
jetpilot10 jetpilot10 is offline
JETPILOT10
Mein Auto: 2000 BMW 540I
I am having similar issue
I am having a similar issue after a tranny install. I believe it's the torque converter. Sound like a metal to metal, ting, ting, ting sound. Had it on the rack and its definitely coming from the front of tranny it he bell housing area, which leads me to belie torque converter.
Jetpilot10
2000 540i Sport
Corporate Pilot / Aerobatic Instructor
Competition and Airshow Pilot
WestWind II (IA-Jet) & King Air 350 (BE-300)
www.tail-wheel.com
Old 01-27-2013, 08:37 PM
Mein Auto: 528i
Are you having any issues with shifting?My car is running and shifting like there is nothing wrong. I also have the noise in park, drive, neutral and reverse. Im gonna take it to the shop tomorrow and hope something is loose in the exhaust system or transmission mount as I find it hard to believe something can just rattle around in the transmission without causing some sort of change to the way the car drives and shifts gears.
Old 01-28-2013, 08:54 AM
jetpilot10's Avatar
JETPILOT10
No Issue
Nope I am having no issues with shifting etc.. I too get this ringing, pinging in Park, Neutral etc.
Jetpilot10
2000 540i Sport
www.tail-wheel.com
Old 01-28-2013, 05:05 PM
Mein Auto: 528i
the link to the sound is here though the phone does not pick up how hollow the ring is
anyone else diagnose anything like this
Old 01-30-2013, 08:16 AM
jetpilot10's Avatar
JETPILOT10
Wow yours is really bad.... I would suspect the torque converter, flex plate area. If it was internal to transmission you wouldn't hear it like that, it would be somewhat muffled.
Time for tyranny shop to have them look in the bello using area for the issue.
Let me know what you find out.
Jetpilot10
2000 540i Sport
www.tail-wheel.com
Old 02-06-2013, 08:53 AM
Mein Auto: 528i
The starter motor was the problem. I took it to an exhustt shop and recommended indy and they were blaming the tranny but i couldnt accept it. Got a remanu starter and the test that convinced me was backing the car up a ramp and the noise went away until it was started on the flat, changed the starter and the car is quiet as a mouse again.
I would suggest anyone having the same experience change it as soon as possible before doing any real damage!!
