Old 01-26-2013, 08:19 PM
Shawn1971 Shawn1971 is offline
Shawn
Mein Auto: 1999 528i
e39 99 528i transmission
I am only getting 2and3rd gear and speedo quit working and traction control light is on and abs light is on
Old 01-26-2013, 11:56 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Get the codes read - report back.
Old 01-27-2013, 07:48 PM
E39/E60 E39/E60 is offline
Mein Auto: E39 528i
ok this happens often when wet outside what i do is manually shift by going from drive to 3rd gear and back up this shifts it then i would check the abs light it could be water just got on it or that it shorted but that would be my advice i have no idea if this is bad for trans ive done it a lot and my trans is still rocking again just my experience
Old 01-27-2013, 08:09 PM
diggyd357's Avatar
diggyd357 diggyd357 is offline
Mein Auto: 97 528I
Wheel speed sensors... rear drivers side wheel speed sensor will cause speedometer issues and front passenger wheel speed sensor affects the shifting . This was the first issue I dealt with when I bought my 97 528i. I had same lights lit and same symptom.
