Old 01-26-2013, 09:38 PM
wkw wkw is offline
Mein Auto: '99 540ia Sport
Rattle with rear sunshade up
Rattles constantly when going over bumps etc. Doesn't rattle when it's down... I checked the nuts in the trunk. I can make it rattle with my hand by tapping in the middle of the rear deck when the shade is up. Driving me nuts. I like to keep the sunshade up to cut glare from headlights. Any ideas?
'99 540iA
Old 02-16-2013, 11:28 PM
wkw wkw is offline
Anyone?
Old 02-17-2013, 03:15 PM
Bwood1 Bwood1 is offline
Mein Auto: 1999 528i, 2002 540i
I would pull the parcel shelf out or at least get it loose enough to where you can look under it. Easy to say, but it requires removing the rear seat (bottom and back), headrests and side trim panels. Then have someone pound from inside the trunk and see if something bonces or is loose.
Good luck.
Old 02-17-2013, 10:26 PM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
Mein Auto: 1996 528i 1999 MB c240
There are two sets of nuts, the trunk ones and a set under the carpted shelve in between that are glued to the underside of the cardboard shelve.
