E34 (1989 - 1995)
Old 01-27-2013, 08:22 AM
David Arabiat David Arabiat is offline
Mein Auto: 1988 m20b20 BMW E34
Radiator cleaners . Any good ?
my cooling system has been slowly leaking coolant (every month i have to add 1 liter of coolant ) .. so for a while ive been using not so good coolant ( coz its cheaper ) since the coolant was leaking anyways ... now im thinking of flushing the system
i ran across this product in the mall ... what do you guys think ? does it really clean the radiator from the possible rust i might have gotten ?
Old 01-27-2013, 11:30 AM
supertech777's Avatar
supertech777 supertech777 is online now
Mein Auto: 1995 525i
The truth of the matter is if you already have a slight leak on your radiator , flushing it might Be worse for it due to it may result In a bigger leak , unclogging some of the rust that is plugging up some of the unseen holes . Being your profile states that you live in Jordan I would start ordering a new radiator . The cooling system of these cars are the achiles heels of the e34 . In short you need a new radiator .....
Good luck
Noel
Sent from my Desire HD using Bimmer App
Old 01-27-2013, 11:36 AM
my radiator is just fine ... i dont think it leaks .... the leakage can be anywhere ... but the pressure test didnt show any apparent leakage areas ....
Old 01-27-2013, 11:49 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Your first post says it's leaking and now you say it's not
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-27-2013, 11:50 AM
BMR_LVR's Avatar
Humble E34 lover
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-27-2013, 11:55 AM
i didnt say my leak was from the radiator .... im just saying every 3-4 weeks i need to add some coolant ... my guess is that there is a small leakage somewhere in the cooling system ... why am i sure that its not from the radiator ? well, because my old radiator was changed ( not due to leaks , but because my car was euro spec with the smaller radiator .. and in summer it would overheat sometimes )
with the old radiator i had to add coolant every now and then .. and with the new one its the same ..
Old 01-27-2013, 12:04 PM
BMR_LVR's Avatar
Humble E34 lover
I guess we're just confused about why you want to flush a radiator when you have a coolant leak from an unknown origin.
Anyway, I would recommend that you find the leak. I don't know about the product you showed. Sorry.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-27-2013, 06:13 PM
BMWFatherFigure's Avatar
Old School
Is your new (current) radiator brass or ali? Ali rads with high phosphate coolant fail very quickly. If yours has only had hi phos coolant then it is possible your car is slowly boiling to cool. No cheap fix. PM me if you want the full explaination. You need a static pressure test on the whole system as well. BTW I've yet to see a pour in cleaner that works. The sad truth is that cheap fixes are temporary at best and can cause damage at worst.
Current:
Previous:
Old 01-27-2013, 08:47 PM
Originally Posted by BMWFatherFigure View Post
.BTW I've yet to see a pour in cleaner that works. The sad truth is that cheap fixes are temporary at best and can cause damage at worst.
Thank you enough said ... i just wanted to get an answer whether cleaners are actually good for the radiator ..
i guess the answer is no ... i'll just stay away from them
thanks
Old 01-27-2013, 08:56 PM
_Ethrty-Andy_'s Avatar
_Ethrty-Andy_ _Ethrty-Andy_ is online now
E34 Converted E30 Fanatic
I have never bothered to use them. i believe they are just marketing. i usually just remove the radiator from the vehicle, put the garden hose on full tit and spray down the holes. gets rid of everything eventually.
Old 01-29-2013, 11:05 AM
paperplane94 paperplane94 is online now
Mein Auto: 1989 525i M20B25
I used the prestone flush stuff. Took out most, if not all of the rusty stuff that was in the cooling system after years of tap water use.
Old 01-29-2013, 11:12 AM
SwissCheeseHead SwissCheeseHead is offline
Mein Auto: 08 G37,94 530i,11 328iT
Does your exhaust smell like burning coolant? It's a sweet smell and very distinguishable. Your exhaust will also be very white. If you don't have a visible leak coming out of your cooling system, your engine may be burning coolant. If that's the case, you may have a larger issue at hand.
2008 Infiniti G37, 1994 BMW 530i, 2011 BMW 328iT
Old 01-31-2013, 03:52 AM
no ... no smell ... no white exhaust ...
