Old 01-27-2013, 10:17 AM
JOHNNY2271 JOHNNY2271 is offline
Mein Auto: E60 530I
07 530i jerk forward when coming to a stop Please HELP
Hi all, I'm new on this forum and try doing a search for this as well but ended up with no answer to my question.
I just got a 2007 530i and notice that when I'm driving the car and coming to a red light or stop the car jerks forward a little right before I stop? I had seen some people with this problem but has anyone gotten it taken care of and what had to be done or replace for this problem to go away ? Any help will be great !
THANKS
John
Old 01-27-2013, 10:54 AM
Mein Auto: E60 530I
Anyone ?
Old 01-27-2013, 11:46 AM
H F H F is offline
Mein Auto: 2005 545i
Originally Posted by JOHNNY2271 View Post
Anyone ?
i had the same problem on my 545.. at the time it was still under waranty.. once they updated the tranny software the problem went away.....
Old 01-27-2013, 11:49 AM
Mein Auto: E60 530I
Thank you H F, by any chance do you know if the tranny software can only be done at BMW ? I'm new to BMW sorry for the rookie questions.
Thanks John
Old 01-27-2013, 12:47 PM
H F H F is offline
Thanks John
not sure.. it would b worth it,,,, to find out if a indy shop can update the tranny. keep reading the posts on this site u will defitnatly learn a tremondous amount. this is a great site.. evryone is willing to help and some of these guys are pretty informative. ive learned more about my 545 in the last 6 months from reading here,,, than i have in the 5 years that ived owned it.... keep looking thru the posts theres alot of info on ur exact issue....
Old 01-27-2013, 01:05 PM
Vapiano's Avatar
Vapiano Vapiano is offline
Mein Auto: Dinan E60 M5 & 2014 550ix
This site is amazing, lots to learn for sure.
Old 01-27-2013, 01:20 PM
Mein Auto: E60 530I
Thanks for the info guys
Old 01-27-2013, 01:29 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Replace your mechatronik adapter
Old 01-27-2013, 01:54 PM
Mein Auto: E60 530I
SFBAY did you have to replace your mechatronic adapter to get this problem fix on your car ? and if so does the adapter cost a lot ?
Thanks John
Old 01-27-2013, 02:11 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Thanks John
It CAN be done outside of the dealerships, but they are probably your best bet. WinKFP software can do the upgrade but I've never been brave enough to try it.
Do you mean sealing sleeve?
Old 01-27-2013, 04:09 PM
Mein Auto: E60 530I
well i'm going to check out this problem this week and will make sure to post the info and what was fix for anyone who is having the same problem.
Old 01-27-2013, 04:50 PM
Mein Auto: BMW 745i
Thanks John
Yes it did fix my and many others tranny issues. Software update won't do a sht.
25$ adapter
23$ sleeve
Dealer knows these parts
Old 01-27-2013, 05:02 PM
Mein Auto: E60 530I
Thank you SFBAY going to check this out 1st thing tomorrow morning.
Old 01-27-2013, 05:07 PM
Frenchyrider267 Frenchyrider267 is offline
Frenchy
Mein Auto: 2004 525i
I'm sure there's more to it than just replacing the adapter and sleeve. Will you have to clean it out with isopropyl alcohol, parts cleaner or anything like that? It's my understanding that its the degraded sleeve allowing trans fluid in the connection creating the tranny malfunction/jerk. Is this correct?
Old 01-28-2013, 07:45 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
Sleeve (electrical connector to the mechatronics unit on the transmission) itself is not the problem. The o-rings on the sleeve degrade and allows the trans fluid to seep out.
Leaking sleeve in itself doesn't cause transmission problems. If the leakage is severe enough and enough fluid has leaked out, DUE TO LOW TRANS FLUID, transmission starts to have problems.
If you don't see any leakage around the sleeve, then it's not causing the trans problems. It's easy to see if the sleeve is leaking.
Old 01-28-2013, 09:19 AM
Mein Auto: BMW 745i
Exactly. But even if it leaks you can add fluid and you'll be fine for a while, but mechatronik adapter is way way more important, bc it's responsible for fluid pressure inside!
Old 01-28-2013, 09:54 AM
DIY'er
I was coming in here to say exactly that...
A seal leaking does NOT make the transmission do weird things. A low fluid level (caused by leaking seal) on the other hand..
He is right--if it's leaking enough to be the source of your issue, it's pretty noticeable
Old 01-28-2013, 12:51 PM
JoeFromPA JoeFromPA is offline
Mein Auto: 01 M5, 08 535xit
THANKS
John
Hi John,
My 08 535xit I just got has the same symptom that feels like a shudder right as I come to a stop. Please let me know if you get a fix for it.
F80 m3 - 20k miles as of April 2015....08 535xit - 120k miles
Old 01-28-2013, 02:33 PM
Mein Auto: BMW 745i
Ppl, don't even think that software update will fix anything.
You had a car for a while and for some reason your sw crashed, or what??? This is ridiculous to think that sw is related, was it what hacked through Internet, or what happened to the old sw??
Old 01-28-2013, 04:02 PM
Mein Auto: E60 530I
Hi everyone, so this morning i went to my shop and try getting this done but the guy was supper busy. I'm going back tomorrow morning to check for low tranny fluid level and any types of leaks. I just got this car not more then a week ago, I just hope it nothing big for i have big plans for the car. I will keep everyone posted for those who has this problem as soon as i know more.
*joefrompa i can msg you as soon as i know more info tomorrow morning.
*bmwoem1 thanks for reaching out to me, I live in Brooklyn but if it does come down to a software update i will hit you up for sure and meet up with you. But as a master tech have you seen these problems on the 5 series before and if so what are the steps to checking/ treating the problem. Thanks again!
Old 01-28-2013, 04:45 PM
H F H F is offline
We'll,, a transmission update fixed that issue on my car and it has never surged comming to a stop again,, and its been over three years since the update was done..So.... i can say for a fact,,,, that a update fixed the problem. and,, have read post here of updates also fixing surging issues on other cars,,,,
i think it depends on wat the problem is... if u dont change ur tranny fluid the silenoids get clogged and can make ur trany surge at different times and speeds ,,,
Old 01-28-2013, 05:01 PM
Frenchy
Okay, we'll I think I know what I need to do then.
-fluid/filter change (I'm at 110k miles)
-change sleeve/o-rings/adapter
-ensure fluid is at proper level when filling.
-reset adaptions.
That's all right?
Old 01-28-2013, 05:16 PM
H F H F is offline
-reset adaptions.
That's all right?
i think frequent fluid change is crutial on these high tech trannys im at 90,000 and just did my 3rd fluid change..
Old 01-28-2013, 06:01 PM
DIY'er
Do you know which version you were using when you had issues and what they upgraded you to? I am at V36 right now.
Old 01-28-2013, 06:02 PM
Vapiano's Avatar
Interesting thread; I am going to change out my transmission fluid in the next few weeks. At 60k miles it seems that this will be considered preventive maintenance. I understand that swapping out the tranny fluid in these cars is somewhat a complicated process and you never really get all the gunk out.
