Old 08-07-2016, 04:57 PM
Brenansmith Brenansmith is offline
Mein Auto: 2004 530i
Starting problem with my 2004 530i
I need help. I recently purchased a 2004 530i and I'm having problems starting. In the morning it seems it will start right up and run fine and idle fine. But more often then not it cranks for a while and nothing... Sometimes it will start for a few seconds then shut off. I pulled the fuel filter and I could blow though it just fine. Not a lot of pressure when I removed the hose on the filter as I've seen in some videos where it sprays out. I checked the voltage on the pump and got about 3.5 volts in some areas with the key in the ignition in the on position but the other term that read 12.5 volts when the key was cranked I had nothing when in the on position.. Battery is good. The car is 170,000 miles. It's strange that it will start no problem sometimes but others I'm stranded. It's usually right after i just started the car that it's the worst. Also I only hear the pump run while cranking and when the car is on. Should I be hearing priming when the key is turned to the on position?
Old 08-08-2016, 10:12 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest! I've moved your question to our E60 5 Series forum, you'll get more help in here.
Tim
Old 08-08-2016, 02:53 PM
BronxE60 BronxE60 is offline
Mein Auto:
As strange as it may seem, I believe the pump turns on as soon as you unlock the doors.
2004 525i
120k miles
Non navi
Old 08-13-2016, 12:19 AM
In need of more help. Could this be a trans problem. Getting ! Next to the gear position indicator
Old 08-14-2016, 04:00 PM
eburnz's Avatar
eburnz eburnz is offline
:D
Mein Auto: Dirty 530i
I've had a similar issue, not sure if it's related or not, but a couple months back I've experience whenever I sit on a slanted hill either up or down and car is off and sits for a couple mins and try starting it back up it always die, it cranks and everything but it won't keep an idle, to fix it I have to Gun the the needle to maybe 2500-3000 rpms and put it in drive and it will be fine after that. This happened to me 3 times overall hasn't happened recently but I'm not sure what it could of been, gas tank is always 1/2 or quarter full when it happened on all 3 occasions..
Another thing is I regular do techron fuel injector treatments maybe this left some gunk got in the path of fuel going to my fuel filter whenever I'm on a hill or all the gunk that's been getting cleaned away from the treatments is finially clogging up the filter idk, but I've never had a issue in 2 months since this last happened so idk...
2004 BMW 530i (Prod: 7/2004)
Sports package | Prem package | Prem sound package | Cold weather package | Light package | 18x8 Matte Black / 20mm spacers: 15mm offset | Carbon Fiber: Grill, Side mirrors, M5 trunk spoiler, LED gear shift knob, Interior trim | Mtech v3 AE | M5 front bumper | Interior white LEDs | Smoked side markers | Muffler delete | Dual exhaust gun metal tips
RIP Selina - 2001 BMW 525i (Prod: 10/2000)
"Call it what you want, it's a BMW"
Old 08-14-2016, 05:21 PM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '04 525i
Originally Posted by Brenansmith View Post
Not a lot of pressure when I removed the hose on the filter as I've seen in some videos where it sprays out. The car is 170,000 miles. Should I be hearing priming when the key is turned to the on position?
That the fuel does not spurt out is a tell tale indication.
Fuel is primed when the door is open or is it when the switch is put to ON....can't remember but the fuel is definitely primed prior starting.I can hear the pump run for a split second.
I would check the fuel pump pressure first.......
Old 08-14-2016, 05:50 PM
Mein Auto:
I have read that the fuel pump turn on when the car is unlocked
2004 525i
120k miles
Non navi
Old 08-15-2016, 12:30 AM
eburnz's Avatar
:D
Usually I hear mine or some weird whine noise whenever I open my door
