Electronic problem I believe related to the crash recognition program
Here is what happens:
When I want to start the car (key in ignition, Pos "0"), the flashers all of a sudden start, doors unlock and the cabin light is on. You can stop the flashers by pressing the central button for them, the light stays on. They remote key is not operating. you have to hit the unlock button - one beep, then lock button - 2 beeps, the light turns off and the car is OK now. Sometimes it happens when I arrive home, just before turning off the engine. It is very similar to the crash recognition program for these cars, which at an iminent crash will do exactly the same plus the airbag(s) would deploy. I had this symptom sporadically for about 4-5 years now - it happened usually in winter once or twice, when I entered a heated garage from the cold. It had to be very cold, like -30°C or lower (this is -22°F or lower). heated garage is above +10°C (50° F). This winter however it started going gangbusters on me, almost every day, no matter what the ambient temp is. I checked the battery, and it checks OK. I checked the ignition switch and it still looks good. Anyone can help me out with this? Can it be a bad contact, and if yes, where? Is the respective module going out, and if yes, which exactly is it, and where is it located? There are absolutely no codes.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
What happens with the other key? have you tried re-initializing your keys?
IIRC the crash recognition program also blows off the + battery cable and clearly that is not happening. This sounds more like it's related to the alarm and remote locking/unlocking, at least to me.
2001 530 Steel Blue Metallic, purchased Dec 03 SP/PP/CWP/Slushbox (I know I know) OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads "Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget BMW CCA member for 12 years |
![]() Maybe the battery cable, airbag(s) and seat belt tensioner are set off by another sensor triggered in tandem with the crash sensor?
Update:
GT1 showed nothing. Tested charging system: OK, checked continuity: OK, checked for loose ground wires: none. Last thing - the battery. Because it's fairly new. Turned out it doesn't hold charge. Replaced the battery under warranty, symptoms gone. All's good. Another thread with the exact symptoms, on a different forum, in case one of you exhibit this.
Symptom is back.
As soon as i put the key in the ignition and barely turn 1/100" (pos I is not reached - the key just moves from pos 00:
Scanned with GT1, and in INPA I got: 512001 DWA-LED flashes after activation 512002 Anti-theft alarm system, false alarm 512003 Central locking unlocks or locks automatically 512004 Central locking button not functioning 512048 radio and reception problem during vehicle access. Contents of defect code memories (not selectable or deletable): Radio - No communication possible ZKE - 94 GM: LED for anti-theft alarm system, open circuit ZKE - 5E GM: Central-locking drive, passenger's door The battery looks strong. Not sure what the problem is. I really need some help with this. P.S.: Also the INPA Diagnosis Test Schedule gave me this: ZKE - 94 GM: LED for anti-theft alarm system, open circuit Burglar alarmsystem (ZKE) zke ZKE - 5E GM: Central-locking drive, passenger's door Seat/steering - column memory slm
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby Last edited by doru; 01-29-2013 at 08:22 AM. |
