Old 01-27-2013, 01:03 PM
Ruff Ryder Ruff Ryder is offline
Mein Auto: 745Li
Question Front Passenger door doesn't open when unlocked
Well, on a sad note, last week I locked the car doors on my 2004 745Li prior to going into the grocery store. When my wife and I returned to the car, I unlocked the doors but my wife couldn't open the passenger door from the outside, however it could be opened from the inside. Would anyone know what the root cause of this could be? Any input, remedy, or advice would gladly be appreciated! Thanks in advance!
Old 01-28-2013, 03:03 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
Not completely sure but possibly the Bowden cable. But it usually doesn't open from the inside either. Just an idea
Old 01-28-2013, 05:40 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '00 740i
The DIY section has a write up about replacing comfort access door handles. Use that to remove your handle with removing your door panel. Hopefully the root cause becomes apparent with the handle off.
2005 745i Individual
Old 01-31-2013, 10:41 AM
djohansen77 djohansen77 is offline
Mein Auto: 2004 745Li
I had a similar problem after I had my windows tinted. They had taken the door card off and slightly bent the rod for the door lock. Just had to get it back to it's original form and the lock moved freely up and down. Not sure if this is the same issue but it is similar.
Sent from my SCH-I535 using Bimmer App
Old 01-31-2013, 12:14 PM
alpinaman24's Avatar
alpinaman24 alpinaman24 is offline
what amg?
Mein Auto: 07 B7,91 735i , 91e30sold
where the outside door handle connects to the cable to open door i bieleve that clip is broken therefore knocking out the cable
