Old 01-27-2013, 03:22 PM
heisnberg heisnberg is offline
Mein Auto: Mercedes-Benz E-320
Samsung Galaxy S3 & '11 X5
Hey guys, I recently upgraded my phone and replaced my iPhone 4 with a Samsung Galaxy S3. I'm trying to figure out the best way to play the music through the truck with my new phone. Is there a Y cable that has a micro usb end instead of the iPhone connector? I also don't have Combox so can't bluetooth stream. Any thoughts?
Old 01-27-2013, 03:42 PM
Fleetman's Avatar
Fleetman Fleetman is offline
Mein Auto: '11 X5 35d & 98 Cherokee
I'm certainly not a knowledgeable one to give advice but to play music, I think, all you need is a USB cable with a micro on the other end....easily obtainable at Walmart with one of their USB cigarette lighter chargers. Plug the micro end into your phone, the USB end into the USB port in the center console and select EXTERNAL from iDrive.....as a reminder, the stereo must be on.....the USB connection does not turn it on.:
Old 01-27-2013, 03:45 PM
Fleetman's Avatar
Old 01-27-2013, 03:50 PM
Thanks, so you don't need an aux cable? I'll give it a try.
Old 01-27-2013, 05:01 PM
russ8128 russ8128 is offline
Mein Auto: X5
I have a S3 and '11 too. Android phones don't transmit audio through their usb ports like the iPhones do via their 30 pin ports. You can use the headphone jack to plug a male to male cord that you'll plug into the center console's aux port. Select it in via the iDrive media section - aux input. No control of the music via the car and no charging.
Truthfully, not very elegant. As an aside you can get a cheap usb flash drive for less than $10 and load it up with music. Plug that into the usb port and you'll see music on the car's screen and can control it. Much better solution IMHO... (or if you have an old iPod you could use the cable - that's what i do)
Hope that helps
Old 01-27-2013, 05:41 PM
Hope that helps
Thanks, do you know how many gigs of storage iDrive has? I have around 11 gigs on my iTunes.
Old 01-27-2013, 07:17 PM
Mein Auto: X5
I think it is just around that (11 or 12 GB). You can check for free storage in the system (don't remember how - sorry). I'm sure it is one of the options under media or menu...
Old 01-28-2013, 03:41 PM
Whippa Whippa is offline
Mein Auto: F350 Diesel 2011
Thats funny ... My Galaxy plays music through the Bluetooth..without wire as soon as I get in...But I do have a 2 yr old Ford Diesel truck...wouldn't expect BMW to be there yet ..
Old 01-29-2013, 07:40 PM
tlim66 tlim66 is offline
Mein Auto: BMW X5 35d
I think you can use the USB to your phone to control the music selection via I drive and use the headphone jack for the audio.
