Old 01-27-2013, 03:30 PM
PeterC4 PeterC4 is offline
Mein Auto: 535xi,328xiC
Missing Files in 48.3
I have downloaded all of the new 48.3 files. After a very recent recoding of my 2012 535xi at the dealer I cannot re-code anything related to the HUD or NAVI screen or DVD in motion. I am missing these files:
Transaktions-Report: Aktion: Codierdaten lesen
HU_CIC [63] [DU58559]
readCPS o.k.
cafd_000000f9-007_003_022 Fehler:
File for "cafd_000000f9-007_003_022" not found! [C012]
KOMBI [60] [DU58559]
readCPS o.k.
cafd_00000069-009_000_050 Fehler:
File for "cafd_00000069-009_000_050" not found! [C012]
Any one run accross this? Also, can anyone verify the size of the last zipped file for me? It is smaller than the rest, but for some reason when I was downloanding some files again the last one came up different. I'm at a loss at this point.
2012 535xi M-Sport, Carbon Black, Cinnamon-Alum Hex, Exec Pack, Tech Pack, HUD, Damper Control, BMW Apps, Heated Rear Seats, BMS Tune
Old 01-27-2013, 03:52 PM
ImSW1 ImSW1 is offline
Mein Auto: F10
readCPS o.k.
readCPS o.k.
Both CAFD's are located in 48.1, 48.2 and 48.3. If you have copies of the earlier psdzdata files you can pull them from there. If you can't locate them, let me know and I'll attach them.
Sean
Shawn to the rescue with the files....but they were there already!! The CAFD files for HU CIC and KOMBI cannot be accessed on my car. Others modules can be accessed. Did I FUBAR something? Other modules seem to work. When I installed the new files first time around I had some incomplete files and thats when I got the first error messages. I downloaded everything correctly and reinstalled my PSdZ data file. To no avail. I cannot get access. Have they locked me out??? Do in need to reset something?
Old 01-27-2013, 04:02 PM
Okay, its a match of MAN and COMPUTER. When I look for the files in the CAFD folder they cannot be found. When I went to add them I got the message they were already there so I replaced them...okay, this means war.
Old 01-27-2013, 04:08 PM
Mein Auto: F10
What is the current I-step (open E-Sys > Expert Mode > open VCM tab > VCM master tab > click "read" in I-steps window > post "I-Step Current") on your car? Did you download the complete 48.3 psdzdata set or the difference dataset? I don't think we've seen the same issues on the F10 as the F20/30, but there is a possibility that the new updated CAFDs could have the new verification stage. Hopefully it's just some corrupted files.
Sean
Old 01-27-2013, 04:12 PM
Mein Auto: F10
Here's the two CAFD's. Just remove the .pdf at the end of the file name and drop them into the applicable folder.
Sean
Old 01-27-2013, 04:31 PM
Sean
Thanks for this. Shawn gave them to me too. Hmmm. When I look in my CAFD file folder they are not there, or I can't see them, but when I go to install them, they are. Hmmm....
Old 01-27-2013, 04:39 PM
This file came from another computer and may be blocked to protect this computer....could this be it? I unblocked it. Let's see.
Old 01-27-2013, 04:41 PM
Sean
I downloaded from the link you sent, but I believe it was the complete set.
Old 01-27-2013, 05:08 PM
Sean
Current I-Step is F10-12-11=503. Try as I might the files cannot be read, but I know they are in my CADF file. Every other module works. But these are not accessible, by me anyway. So my HUD and DVD cannot be coded. Interstingly, my DVD in Motion CD has been locked out too, it iwll not work. It did last update. Me thinks I have been locked out.
readCPS o.k.
readCPS o.k.
Old 01-27-2013, 06:24 PM
Mein Auto: F10
[C012]
F10-12-11-503 is related to the 2.48.2 psdzdata set. I have the same I-Step in my car and have no problem accessing HU_CIC using E-Sys 3.18.4 and psdzdata 48.2 (I don't have HUD). I wonder if the files are "hidden" or have inherited some strange permissions from your computer. There's no reason why you shouldn't be able to see the files.
Sean
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
readCPS o.k.
readCPS o.k.
you should call the DVD place and tell them of your issue...see what they say about the cd not working as it should work because its has your vins...
Old 01-27-2013, 06:26 PM
Okay, finally got my dvdinmotion disk to "activate while moving" in a very unconventional way. I don't know if I could ever repeat the installation steps, but something is up. Hopefully I will fix this with a complete re-load of my PSdZ Data file. We'll see.
Old 01-27-2013, 08:54 PM
It works Now
Apologies to all.
It really helps when you update your PSdZ data files that you update the
C:\ESysData\psdzdata\swe\cafd
with the new psdzdata files. Get rid of the old psdzdata file. Also, take care to ensure the download was absolutely complete.
I was updating my back-up file?!!.
Thanks Shawn..
Old 01-28-2013, 08:21 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Apologies to all.
Thanks Shawn..
Your welcome.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
