High vs Low cluster computer function? - Bimmerfest - BMW Forums
Old 01-27-2013, 11:42 PM
teklord69 teklord69 is offline
Mein Auto: 2001 330ci 5-Spd
I have the "low cluster" and through the left stalk I can cycle my screen to show MPG, Temp, Avg speed, Miles to empty, etc.
Where is the control for the these functions on the "high cluster" ? Is it on the MID with the button labeled "BC"?
Old 01-29-2013, 10:35 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The button on the end of the turn signal lever cycles the items on the cluster readout.
You need to get a copy of the Owner's Manual - Radio and Information Systems. This describes how to use the MID to select desired readouts for the cluster. You should also get the general Owner's Manual. There are many embedded features that you won't find w/o the manuals.
Old 01-29-2013, 11:23 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Yes...the main display for the OBC for BMWs with the HIGH MID & HIGH CLUSTER is either the MID or the Nav screen.
The control of the OBC (like start/reset/set of the OBC features) is done with the buttons on the MID or the Nav screen.
But, you can still program ALL or just your select favorites of the OBC features to appear in the insturment cluster's 20 digit alpha/numeric display...and this is done by pressing inward on the turn indicator stalk until PROG 1 appears (then either press the SET button on the MID or Nav screen...and ALL the OBC features will appear...or press & hold the stalk until PROG1 appears, then begin to pick the OBC feature you want to appear by pressing the buttons on the MID or Nav screen...then when your done, press the SET button.
This will then allow you to press the BC button on the turn indicator stalk to call up the OBC features on the instrument cluster display (as long as there are no PRIORITY 1 Check Control warnings). The display on the HIGH cluster has first priority to the Check Control system...thus any Priority 1 or 2 warnings will wipe-out any OBC features if they occur because they have first priority of the display...where as the MID or Nav screen is the display for the OBC.
Q {BMW CCA Member #191509}
(SOLD)
