Old 05-17-2013, 07:24 PM
KingTrack KingTrack is offline
Mein Auto: 750LI
Brake Dust?
Got my F02 about two weeks ago now and the worst by far has been all the brake dust, pretty impossible to keep the wheels even close to clean. Any tips or tricks to reduce this or an easy way to clean?
Old 05-17-2013, 08:39 PM
aom aom is offline
Moderator
Mein Auto: 750i 740i 330ci
hmmm, this is really really strange... OK, so one of the worse things about all my past BMWs (E38 E39 E46) has been that horrible brake dust. I'm talking in 10 miles you've already got a gray coating and after 50, forget about it. However, on my F01, I can drive 300 miles and there's almost NO brake dust in comparison.
Is it new? Maybe you're just breaking in the pads and discs in which case more brake dust would be generated.
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: http://www.bimmerfest.com/forums/sho...d.php?t=725889
Old 05-17-2013, 08:45 PM
Mein Auto: 750LI
This is actually my first BMW so the only thing I can compare it with is Cadillacs and Benzes and its worse in my experience. I have ran across other people on this forum saying the same thing so I assumed it was a regular issue.
The car is an 09 so not new, but new to me lol.
Old 05-17-2013, 08:46 PM
Snorlax Snorlax is offline
Mein Auto: _
Easy fix. Get Akebono ceramic brakes or another brand of your choice. You can get them from tire rack. I had this same problem drive me nuts. After switching, brake dust almost totally gone!!!
Old 05-17-2013, 08:48 PM
Mein Auto: 750LI
Will look into it, thanks! Your car looks great btw!
Old 05-17-2013, 08:52 PM
Mein Auto: _
Thanks! Got new rims on the way....can't wait! :-)
Old 05-17-2013, 08:57 PM
aom aom is offline
Moderator
Yes in comparison, that makes sense--MB and Cad is probably bettery with that. Lexus also has pretty much no brake dust too. Raj's idea of going aftermarket would be a great choice, plus you might get better performance out of it!
Old 05-18-2013, 06:08 AM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
Brake Dust?
Don't need to even think about this topic....get the Akebonos. You can get them from tirerack or you can get the part numbers there and search amazon.
Seriously though just order them and your brake dust will be gone. This is an easy DIY.Click image for larger version
ID:	377132Click image for larger version
ID:	377133Click image for larger version
Old 05-18-2013, 06:11 AM
Deutsch100 Deutsch100 is offline
Mein Auto: 2012 Active Hybrid 7
Been discussed many times. The 2009 7 Series does NOT have Regenerative Braking (a la Hybrid cars). 2010-2013 have Regenerative brakes, and you can literally drive everyday for weeks, and there is almost no dust. My 2010 750i and 2012 ActiveHybrid 7 had the cleanest wheels of ANY German car, or European car. It was amazing. Yes, Akebono brakes are your only hope!!! Enjoy your car!!!
2013 Rolls Royce Phantom Sedan,
2013 Phantom Aviator Coupe, 2013 G63 AMG
Old 05-18-2013, 03:28 PM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
@Deutsch100, you got yourself a Phantom coupe?
2011 750i
Old 05-18-2013, 03:49 PM
Added a 2013 Phantom Aviator Coupe. It's a really cool car, only 35 made worldwide. Just could not resist
Old 05-19-2013, 01:16 PM
Mein Auto: 750LI
Thanks for all the advice guys, will look into doing that!
A bit off topic but while looking at the wheels today noticed a bump in the front drivers side tire, not huge about maybe half an inch. I know this is a bad sign and have heard people complain about it being an issue with the runflats. I've never owned runflats though so is this something I should replace right away or since its a run flat it can wait a bit?
Old 05-19-2013, 01:40 PM
aom aom is offline
Moderator
Ah, Deutsche, thanks for that info. That explains so much. It's really a crazy difference (at least between my older BMWs and this one). Hmmm, but I wonder, that does make replacing pads/discs any more difficult?
Old 05-19-2013, 01:43 PM
aom aom is offline
Moderator
I'd replace it. I'm always super sensitive about tires since they're the only things connecting you to the ground and then only a few sq inches of it at any time. I'm really debating going with just normal tires though for next time.
Old 05-19-2013, 01:47 PM
famaash famaash is offline
Mein Auto: Donkey cart.
Brake Dust?
Thank you for the comments guys. It is driving me nuts.
Old 05-19-2013, 02:55 PM
Mein Auto: 750LI
Yeah that's what I'm debating on now, Michigan is filled with potholes so not sure if this tire makes any sense here.
Old 05-19-2013, 03:54 PM
aom aom is offline
Moderator
Chrisf02 mentioned he swapped it out and the car rides so much better (which I can only believe). I'm going to do it, I just need to figure out a reasonable backup of some sort since I sometimes go on trips and can be in the middle of nowhere.
Old 05-19-2013, 09:14 PM
dagoo98's Avatar
dagoo98 dagoo98 is offline
Mein Auto: 2014 BMW 650xi Gran Coupe
It should be replaced right away....essentially the only thing holding that tire together is the sidewall. The first significant pothole you hit at a moderate speed will blow the tire at the spot. So happy that bought the wheel and tire package because I'm in New York. I've been through 5 tires and 2 wheels already!!!!!
Old 05-19-2013, 10:02 PM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
Just ordered the Akebono pads as i can't take the dust anymore . Next is tires, simply HATE these run flat tires .
Old 05-20-2013, 10:01 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Re: Brake Dust?
Seriously though just order them and your brake dust will be gone. This is an easy DIY.Attachment 377132Attachment 377133Attachment 377134
You made me go and have this done! Picking my car back up tomorrow.
To answer OP question... I have owned three Seven Series and they ALL have immediately gotten a set of Akebono Euro Ceramics!
The first and best mod one can perform on any BMW.
~Big Marcus
Old 05-20-2013, 10:34 PM
Mein Auto: _
~Big Marcus
Pics tomorrow please.
Old 05-22-2013, 10:39 AM
TXSTYLE's Avatar
Re: Drum Roll... My F01!
My stockers are back on because I was having my suspension re done and I'm also doing my car off at dealer to repair this oil pump whine. Don't want my good **** on while the car is being serviced.
But here are a couple pics:
~Big Marcus
ID:	377983   Click image for larger version
Old 05-22-2013, 10:56 AM
Mein Auto: _
~Big Marcus
Clean! I like it. On my list when my new shoes come in a few weeks.
Old 05-22-2013, 11:00 AM
wjjklj's Avatar
Brake Dust?
~Big Marcus
Glad I could inspire you! Brakes look great. It is amazing the difference it makes. Zero dust and clean wheels. Now I need some Vossens! By the way..I kept the Mtecs. I still get an error if they come on during the day but it quickly goes away. I will live with it for how much better the lights look.
Old 05-22-2013, 11:52 AM
TXSTYLE's Avatar
Re: Brake Dust?
Thanks! Yeah with my Akebono and now painted calipers, my wheels have a nice environment to be showcased.
Yeah I am still very content with my Mtec eyes.
~Big Marcus
