Old 01-27-2013, 07:14 PM
THEHULK THEHULK is offline
Mein Auto: 2000 BMW 540I
Testing ccv
I'm attempting to stay ahead of possible maintenance issues. Just checked crankcase pressure from both the dip stick and the oil fill. Both readings about -6"wc with a warm engine. Look good or what should they be? Should this be done with a cold engine?
Old 01-28-2013, 01:30 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I'd start here:
- How to test the crankcase ventilation (aka CCV, CVV, PCV, CPV, & OSV) pressure regulating valve system (1)
Old 01-28-2013, 04:21 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Should be between -3 to -5" WC, IIRC.
2000 540/6 Slightly tweeked...everywhere
Old 01-28-2013, 07:25 AM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
So he's good @ -6. Nice gadget.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
Old 01-28-2013, 07:54 AM
Looks like he's got a little too much to me.
Old 01-28-2013, 08:52 AM
Fudman's Avatar
Fudman Fudman is offline
See this thread and this post (#23) for CCV operation & testing on a warm engine.
http://www.bimmerfest.com/forums/sho...d.php?t=445403
http://www.bimmerfest.com/forums/sho...7&postcount=23
While your pressure is high, you do not have a problem (YET!).
Old 01-28-2013, 10:14 AM
My CCV system was original, at least I'm 99.99% sure it was. 106k, FL car. No gunk, no mayo. Nothing was cracked or plugged. It was actually still working. But I can really tell the new CCV system sucks alot harder when you put your hand on the oil filler cap opening. Wish I had a tool to measure the befor and after. I guess a old fashion Vac gauge would of worked.... Doh!
Old 01-28-2013, 04:34 PM
Thanks your all very helpful.
Old 02-19-2013, 06:24 AM
Hey guys. Look like my CCV was bad. I just replaced and had a big rip in the diaphragm.
Tested the new one with a manometer and has reading moving around from 3 to 6" WC. Easy job took less than 2hours. I highly recommend the use of a manometer to test.
Old 02-19-2013, 08:24 AM
bluebee's Avatar
Thank you very much for being a good netizen, by stating the original values, how and where you tested the inches of vacuum water column, and for the update as to the problem, all with an excellent close-up picture of the results.
Kudos to you - you're obviously intelligent, and caring of others.
So that the NEXT person easily finds this information, I usually post to the one 'canonical' thread on the topic, but I think we actually have two good threads for testing the CCV:
> E39 (1997 - 2003) > Cute little trick to diagnose blocked CCV system...
> E39 (1997 - 2003) > How to test the BMW E39 pressure-controlled crankcase ventilation system (CCV)?
So I posted your results to both. That way, others are sure to find it in the future, long after we're gone.
EDIT: BTW, if someone could EXPLAIN why the tear in the CCV of this thread resulted in greater vacuum, I'd be glad to annotate a separate diagram with the information.
Here's what we currently have for annotations - but if you can give me a paragraph which explains how a tear caused more vacuum, I will create a new one.
