Rear spacers causing inner tire wear? - Bimmerfest - BMW Forums
Old 02-18-2013, 03:08 PM
King 5's Avatar
King 5 King 5 is offline
Send a message via AIM to King 5
Mein Auto: 1997 BMW 528i
I am thinking about getting spacers for my rear wheels to make them fit a little more flush with the wheel well but I had question regarding tire wear. Will putting spacers cause more wear in the inside of the tire? I know that our cars already have some negative camber in the rear, 10* maybe, and would adding spacers create a smaller more concentrated contact patch for the inside of the tire causing more wear?
1997 BMW 528ia 2/97
2004 BMW 330ci 4/03
2008 BMW 335i 3/08
Old 02-18-2013, 05:04 PM
champaign777's Avatar
i belieave spacers do not change negative camber, if you have -1.5 camber before you will have the same -1.5 with spacers
Old 02-19-2013, 07:26 AM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
Low tire pressure is the biggest cause of inner tire wear.
