Old 01-28-2013, 12:40 AM
RazaF02 RazaF02 is offline
Mein Auto: 2010 730 LI
droning noise at 90kmph
Hi beemers,
A newbie here - i drive 2010 BMW 730LI with 750LI's rear body kit. The issue is, there is a bad droning noise at 90kmph onwards, initially i thought the old RFTs must be the reason, but i changed the tires recently with non-RFTs and i am sure its not from them, wheel bearing also double checked, all of them are working fine. then what could be the reason this drone?
Old 01-30-2013, 03:45 AM
Avipitz Avipitz is offline
Mein Auto: 2012 730i
Hi Raza,
I have no idea regarding your problem, but I also drive a 730 and would like to see a picture of that 750 rear body kit if possible.
Thanks.
Old 01-30-2013, 09:29 PM
its the same rear bumber that comes in F02 750li - nothing special.
