Old 01-28-2013, 07:02 AM
bkc0508 bkc0508 is offline
Mein Auto: 2006 750LI / 2012 2500HD
valve stem seals question
Well looks like I am going to have to do seals. Does anyone have a parts list for this job
I know seals
Valve cover seals
Cam cover seals I think
I know I need the alignment tool.
Old 01-28-2013, 05:36 PM
bmwoem1 bmwoem1 is offline
Regional Sponsor
Mein Auto: X3
If you're taking the heads off, then you need head gaskets and head bolts. You will also need upper timing case cover gaskets and vanos gear bolts
Old 01-28-2013, 05:41 PM
I am planning on doing it with heads still on. In the car
Old 01-28-2013, 05:59 PM
Regional Sponsor
Mein Auto: X3
That's how I usually do them also (I'm a BMW tech). I just did a set yesterday actually.... I needed the following: valve cover gasket set (comes w/ all o-rings and seals), upper timing case cover gaskets, vanos bolts, vacuum pump gaskets and of course the valve stem seals.
Old 01-28-2013, 06:12 PM
Great do you know if the bolts come in part 11127551822 or is overkill for this job. Do you find it fixes the oil consumption or is it a valve guide issue. We have 97k on the car. This is the wife's car so I got to do it right. Need this fix to last at least 60 k
Old 01-28-2013, 07:04 PM
Regional Sponsor
Mein Auto: X3
I'll have to check that part number when I get a chance... If that number is for the gasket set, then it does not include the Vanos bolts. The seal replacement fixes the consumption issue about 90% of the time... I have had a couple cars that needed new heads due to excessive guide wear
Old 01-28-2013, 07:05 PM
Would you be so kind to post the part number for the bolts.
Old 01-29-2013, 03:25 AM
Regional Sponsor
Mein Auto: X3
Valve cover gasket set bank 1:
11 12 7 513 194
Valve cover gasket set bank 2:
11 12 7 513 195
Vanos bolts:
11 36 7 501 423 (you will need 4)
Old 01-29-2013, 03:27 AM
Regional Sponsor
Mein Auto: X3
P/n 11 12 7 551 822 will include the head gaskets, which you said you won't need. This part number does include the Vanos bolts
Old 01-29-2013, 03:34 AM
Regional Sponsor
Mein Auto: X3
The p/n that I gave you does not include the valve stem seals
Old 01-29-2013, 06:16 AM
I came up with this as a break down does this look right to you
valve cover
11127513194
11127513195
Upper Timing Case seal
11147506424
11147506425
Vanos bolts
11367501423 x 4
Air pump seal
11667509080
Valve Seals
11340029751 x 2
Valve Keeper
11341461405 x 10
Cam seal ring
11311705512 x 4
Old 01-29-2013, 06:52 AM
So does part 11127551822 not come with the seals. I cant find a break down for the part.
Old 01-29-2013, 09:09 AM
Regional Sponsor
Mein Auto: X3
Yes p/n 822 will come with the valve stem seals, also the head gaskets and some other o-rings you said you're not gonna need. Also, you listed the keepers and camshaft seals... I normally reuse the original ones
Old 01-29-2013, 09:37 AM
Thanks for the follow up..I added keeps just in case i drop one.. Its been awhile since I have done any seals. I wasnt sure on the camshaft seals. I think i will do the list since it a good bit cheaper than the p/n 822 I am planning doing this in next few weeks.
Old 01-29-2013, 05:26 PM
What sealant do you use. The TIS calls for Drei Bond 1209
Old 01-30-2013, 04:13 AM
Regional Sponsor
Mein Auto: X3
That drei bond is really just loctite. But that goes in between the head gasket and the lower timing cover, you're not taking off the heads. If you're referring to the seal between the upper timing case covers and the valve cover gasket, then I use black silicone RTV. Do you have the right tools to do this with the heads still on the car? It's pretty tight in there, I've found a lot of tool sets that are too big for this particular engine
Old 01-30-2013, 04:24 AM
Cool I should have some black rtv. I didn't know how strict bmw was about sealant. Yeah I should have all the tools. I was Mercedes tech for 4 yrs before that Chevy for 5 yrs. Snap on got plenty of my money I actually kept all them. Thanks again for your help
Old 01-30-2013, 07:21 AM
Davidf Davidf is offline
Mein Auto: various BMW's
I suggest you stay away from silicon RTV. IMHO, Permatex #2 is more appropriate for this job. I agree that the cam seal ring(s) does not need to be replaced. I also suggest following TIS when doing this job (specifically cam removal) as it gives important precautions on what to do and what NOT to do. Leaking valve seals usually contribute to carbon build-up in the secondary air ports. Removing the heads to replace the seals offers the opportunity to clean the carbon out of the secondary air ports. By the time you disassemble the head to get to the valve seals, removing the heads are just a few steps more work. Head gaskets are pricey, but new bolts are not. Probably adds about $250 in parts costs to remove heads.
I also have leaking seals and will be doing this work soon. I am debating head removal or not as my engine is throwing the "low flow secondary air bank 2) fault code. Carboned up for sure. AGA is supposedly comiing up with a cleaning kit, but will cost about $250 which is same as added parts cost to remove heads. What to do???????
Old 01-30-2013, 02:37 PM
Regional Sponsor
Mein Auto: X3
He has a 750 (n62tu), So no secondary air ports to worry about.
Old 02-08-2013, 01:04 AM
SFbay SFbay is offline
Mein Auto: BMW 745i
So you're saying your 2006 bmw 760li with 17k miles needs valve seals???? Hmmm smth isn't right here, or am I wrong?? ) lol
Old 02-08-2013, 05:31 AM
LOL, that would be unusual for sure. I also have a '04 545i with 112k miles that needs valve seals. Same engine as the 745i(L). Sometimes I forget what forum I am posting on...7 or 5 series...
Old 02-08-2013, 06:56 AM
Hey bmwoem1
Is that cam tool really need or can I use a bolt the balance to put on TDC and mark the cam gears and chain. Trying to save the cash on the tool since I am sure this is the only one I am going to do.
Old 02-08-2013, 11:15 AM
Regional Sponsor
Mein Auto: X3
Yes, the tool is needed to do it correctly without any issues. It's probably possible to do it without, but if the timing is off, then you will have to take everything apart again. There really isn't a spot to mark the gear to the cam, it's really close to the bearing cap. If you took off just the bearing cap and marked it, you would find the hook ring seals for the Vanos, I don't suggest you put anything on them.
Old 02-08-2013, 11:25 AM
Regional Sponsor
Mein Auto: X3
Just a thought.... What if I rented them to you? PM me if you're interested
Old 02-08-2013, 12:12 PM
Stephen Max Stephen Max is offline
Mein Auto: 1998 M3, 2004 545i
I see you are here in Austin. I am about to do the same thing, but I am definitely going to pull the heads to get at the carbon. I bought the cam alignment tools already. If you want to borrow them after I am done, let me know.
