Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 02-14-2013, 04:12 PM
ChasR ChasR is offline
Mein Auto: 335d, E28 M5, Clubman S
I have extended maintenance, but am out of warranty. I do believe I am the first 335d tune by Mach V.
Old 02-14-2013, 04:37 PM
335dFan's Avatar
335dFan 335dFan is offline
Jumping Jack Flash
Mein Auto: 2011 335d
Have you conjured a way to measure the delta, or will you be reporting using the so-called "butt dyno"? Whatever method I will be keen to hear.
Did you talk to Dan about what he would charge for a re-flash? That probably won't be relevant for you, but it might be for me because I have only 10k on the odometer.
Old 02-14-2013, 05:06 PM
62Lincoln's Avatar
62Lincoln 62Lincoln is offline
Mein Auto: 335d
x2
I would also be interested to hear what a reflash will cost. I've had the Evolve tune for several months, and have had to reflash once already due to the EGR and associated updates. I was using VS Motorsports, but that ship has sailed, obviously.
To your question about the Evolve tune, I haven't dynoed, but the improvement is noticeable, and, at least with my car, the driveability was markedly improved. I would highly recommend the Evolve tune to anyone, as long as they understand the need to pull the DDE for the initial tune install, as well as subsequent reflashes if needed. Money well spent.
Old 02-14-2013, 06:25 PM
I have before data from my G-meter, so I can do a a comparison.
I haven't asked Dan what a reflash costs. If your ECU has the port on the heatsink side like mine, I'd expect the reflash to cost more than the $95 VS Motorsport charged.
Old 02-14-2013, 07:30 PM
335dFan's Avatar
Jumping Jack Flash
Reflash
Actually, at the risk of appearing totally disingenuous, I do know how much Dan said he would charge for a reflash. I was just curious if the number had changed. It was just about the same as what was just said about the VS Motorsports cost. I had asked him all these things when I talked to him originally. I am having a considerable amount of suspension work done in 2-3 weeks, and my second major goal was going to be a JBD, but now am toying again with the idea of a real tune job. Decisions, decisions.
Am just a bit worried about the warranty issue. Perhaps unnecessarily.
Old 02-15-2013, 04:33 AM
Axel61's Avatar
Axel61 Axel61 is offline
Mein Auto: 335d
Decisionas are made every day and People mess up, your choice of either going JBD or Flash is something you must dwell on and base yourself in which one is fit for you. I for one have been using the BENCH flash from RENNtech NEVER failed on both cars (02 MCS and 335d). Piggybacks a la JBD are good but if you ask most of whom use it they say its the best bang for the buck. Terry does an exceptional job but this cannot be compared to a flash either done by RENNtech or any other Flasher out there, you pay money but but you get the best of your vehicle not to underestimate JB. Its a hard choice but Id take the flash before a piggyback. I am at 307 whp with RENNtech and planning to add the WAGNER IC either today or tomorrow and then dyno and provide info in a new THREAD in all forums I am in, so amigo the ball is in your court and honestly I wish you the best of luck in deciding who venue you take and the best of all enjoy it!!!! Like most of us are!!!
P.D> If you are risky guy like SOME of us here go for it, but if you worry about warranty issues then forgetabout it Capiche!!
RENNtech Flash, WAGNER IC,Koni FSDs,Execuhitch,VMR710 19"
Old 02-15-2013, 07:50 AM
I looked at three options, being out of the warranty period. JBD, Evolve and RENNtech. I eliminated RENNtech due to cost. RENNtech has a great reputation, but so does Evolve. I chose Evolve over JBD due to Evolve's claim that their tune improves fuel economy by 10%. JBD has no positive effect on fuel economy in normal driving. If Evolve's claim proves true, it will be cheaper in the long term than JBD. There is little doubt that JBD is the most bang for the initial investment $ and there is the warranty issue with Evolve and RENNtech.
Old 02-18-2013, 07:56 AM
I got the ECU back on saturday and installed it. Seat of the pants dyno indicates a significant increase in horsepower and torque. I'm very glad I installed the Quaife. In my commute, it behaves just like it did before the flash except that, if you press the go pedal to squirt through a hole in traffic, you find yourself going 90 mph instead of 80.
Old 02-21-2013, 06:59 AM
jashearer jashearer is offline
Mein Auto: Holden Wagon & Sedan
How about that G-Meter data?
Jay
Rover - 2013 Holden Commodore SV6 Sedan
Clark - 2013 Holden Commodore Sport SV6 Wagon
Brumby - 1955 Holden FJ Ute
Old 02-21-2013, 11:13 AM
G-meter is in the car. Data in the next few days.
Old 02-21-2013, 03:29 PM
I made one run today with a poor start. 13.83@100.7 in the 1/4, That is an improvement over pre-evolve of .52 seconds and 4.4 mph on a run with a great start. Rolling improvements, which shouldn't be affected by a poor start, of .25 sec. in 30 to 50, .33 sec. 50 to 70 and .63 secs in 50 to 80.
Old 02-22-2013, 05:42 AM
Jay
Old 02-22-2013, 06:20 AM
335dFan's Avatar
Jumping Jack Flash
So, in your preliminary evaluation, it was worth the money spent, eh? Subjectively, where do you feel the improvement? Off the line? Pedal down at 30, 60, 90? I guess maybe you don't have a lot of places to try the pedal down at 90, at least if your location is like mine. Even pedal down at 60 is chancy given how fast it gets to 100.
Mods, etc: ACS M3 Sports Springs, JRZ RS1 Dmprs, Quaife LSD w/VAC finned diff cvr, M3 Rear SF Bushings, M3 Sways, M3 OEM front and rear Susp Comp Kits (except strut brace), Ground Control Caster/Camber Plates, JBD 100%, Stainless Steel Brake Lines, non-stgrd Apex ARC-8 18" wheels & Nitto Motivo tires (for winter OEM 17" wheels and Blizzak LM-25 tires).
Old 02-22-2013, 10:26 AM
Let me get in another couple of runs with a good start, I feel like I can shave off a couple of tenths and add a couple of mph. Off the line is going to be traction limited. Needed more before Evolve and still do.
Once rolling, it is faster across the board. The power band is so broad and relatively flat that the car is simply faster by every measure. Definitely worth the money. I've spent thousands on cars to get 1/4 the benefit of the $800 evolve tune.
Old 02-23-2013, 07:40 AM
mcoupejeff mcoupejeff is offline
Piloto
Send a message via AIM to mcoupejeff
Mein Auto: ///M5, X5D
It's $800 now?!
Edit.. I see this on first page upon re reading, is this a price jump from vs?
now-2000 M5
now-2009 X5 D
former-1999 M Coupe
former-2000 TDI Golf
Old 02-23-2013, 09:34 AM
I think it's up $100.
HTML code is Off
