Old 01-28-2013, 01:58 PM
smoothy22 smoothy22 is offline
Mr. Davis
Mein Auto: BMW 745 LI
Adding transmission fluid
I have a 04 745li. Anybody familiar with how to add transmission fluid if I need to top it off?
Beamer 745Li
Old 01-28-2013, 03:14 PM
Ultimate745i Ultimate745i is offline
Ultimate745i
Mein Auto: 2004 745i
From all that I've read, you should never need fluid unless you 1) have a leak or 2) planning to change your fluid.
You have to drop transmission pan and do other stuff to do it. There's no "add port"(under hood) or even dip stick for transmission on our cars...unfortunately.
Hope someone gives you more expert advice/info.
Fun Doesnt Come Cheap!
Old 01-29-2013, 09:55 AM
flylomo69 flylomo69 is offline
Mein Auto: '04 745Li
Smoothy22, the advice Ultimate745 was as good as it get. If you think you need to check the fluid level, you must have vehicle running in Park on a lift and the tools for removing the filler screw. Be very careful when removing the filler screw, after feeling the screw is at its last thread, slowly back it out, fluid WILL come out which is normal, and the screw should be immediately tighed back up. If nothing trickles out, then add until it starts flowing out and immediately put the filler screw back in. Same procedure as checking rear-gear oil. Hope this help...
Old 01-29-2013, 10:05 AM
inspi inspi is offline
Mein Auto: 03 BMW 745i, 06 BMW 750Li
When You checking the fluid, transmission should be cold. 40-50 deg C max checking with diagnosis software or infrared thermometer
INSPI
