7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
has anyone replaced a coil??
came out the other morning started vehicle and it shaked like crazy!! check engine light came on. ttok to dealer and they said i needed #1 coil. has anyone ever replaced one and what is the difficulty rating to replace?
easy takes 10 min
i work on cars for a living so say 20 mins |
thanks for the info. i am pretty mechanically inclined so now just got to find one to replace it
Actually it should take no more then 5 minutes
To change the #1 coil &only that long cause you have to remove the engine covers Sent from my GT-N7000 using Bimmer App
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
See the spark plug DIY threads, it explains how to remove some of the coils if they are in a tight space. I didnt pay attention and actually broke one of them while forcing it into the hole. It was much easier after I followed the thread.
Im not sure, but I think you can run the engine and disconnect each plug by unplugging the coils one at a time. The one that doesnt affect the engine is the broken one usually. Alternatively connect to an OBD reader and google the code for the cylinder number. |
Also make sure you don't have a vacuum leak it can also give you a rough idle.
Also, I like the way your car looks, what kind of options did it come with? My car is a silver color, but not as light as yours. |
Only vac lines are on the pump, the elbow boot from maf and one of them goes from the plastic union (look on top of left/driver side wheel well area in engine bay) down to the left/ us driver side down to the pressure regulator on the fuel filter, the other i didn't follow to see where it leads
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i |
thanks for the info gents. does anyone have a link to a parts manual so i can get the part #
You can get part numbers from realoem.com
Fcpeuro sells them cheap also...
i stand corrected 5 minutes ....
thanks all i will order from one of those sites tonight.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
