E90/E91/E92/E93 (2006 - 2013)
The E9X is the latest evolution of the BMW 3 series including a highly tuned twin turbo 335i variant pushing out 300hp and 300 ft. lbs. of torque. BMW continues to show that it sets the bar for true driving performance! -- View the E9X Wiki |
I love BMW (I'm on my 3rd) but I am increasingly disappointed with them. First, they decided to use run-flat tires and remove a spot for spare. This led to a very harsh ride and sometimes dangerous situation with certain potholes. Now, with nearly 40K miles on my 2010 BMW 328i xDrive, they refuse to replace brake rotors and pads. The dealership is claiming that there is a rust ring and that the only solution is to pay them $1200+ to replace the rotors and that it's not covered under warranty nor under maintenance.
2010 328xi Space Gray/Black, Premium, Navigation, V1 and more. 2005 X3 3.0i Metallic Silver/Black, Premium+Cold packages, Xenon, Navigation, Premium Sound, Steptronic, Servotronic, PDC, Heated Seats/Wheel, Bluetooth, V1. |
I'm really confused. How are certain potholes more dangerous to different tires?
And don't all rotors have rust rings? They aren't made of alloy or stainless. Once you replace them the next pair will develop a rust ring guaranteed.
Ordered: March 7, 2008 Built: March 17, 2008 At port: March 19, 2008 Shipped on Graceful Leader: March 21, 2008 Arrived Port Hueneme: April 11, 2008 At dealer's: April 19, 2008 Delivered: April 21, 2008
Stupid question perhaps, but can you turn a wrench? Have a jack and jack stands? Or know someone with the aforementioned items/abilities?
Changing rotors and pads on all four corners for most vehicles is a 2-3 hour job (with a break for lunch and brew or two). The day I paid a dealer (or anyone) $1200 to replace rotors and pads is the day hell freezes over.. |
)Brakes are covered under maintenance. Perhaps get a second opinion if there is another dealer near you. Otherwise, call BMW NA Customer Relations at 800-831-1117, tell them exactly what the dealer told you and that you believe the repair should not be excluded from the maintenance coverage. They will investigate and either explain to you why the dealer's position is justified, or come down hard on them for trying to charge you for a covered repair. If you are feeling charitable you can argue your case with the dealer first. Make them show you exactly what it is about your brakes that the maintenance plan does not cover and why. Casually mention that you disagree and will take it up with BMW NA and they might suddenly decide to "do you a favor" and cover the work. You still have the option to go over their heads if needed.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
why do you need the rotors and pads replaced?
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
+1 - has the car's computer indicated the brakes need replacement? The maintenance plan covers maintenance "as determined by the Condition Based Service indicator". A few items are time based (brake fluid- every 24 months, but not pads & rotors), but most are wear based.
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! Last edited by tturedraider; 11-09-2012 at 10:08 AM. |
So sorry for the long delay in my reply but I've been swamped.
Essentially, the light came on but the dealer said that the wear on the brakes wasn't enough to merit a replacement. So why then did the light come on? They then reset the light. Months later I feel that the brakes are worn but they claim that it's still not enough. I'm also disappointed in this particular dealership. I brought my car in for a different problem. They claimed to fix it (after keeping my car overnight) but then the problem re-appeared. I'm frustrated. Quote:
But as far as the "rust ring" requiring replacement of rotors goes. I believe the dealer is giving you a line of BS just to stick it to you. Next they will be telling you that the air in your tires needs to be changed. I would find a new dealer ASAP.
94 318i, 97 528i, 07 335i |
Couple ideas. Are you able to take off one of the road wheels and physically examine the pad thickness? Also need to caliper the rotor width in mm. Look also for a 'lip' on the outer edges of the rotors. Make sure the brakes are cool before doing this. Btw you typically can look for the 'lip' with just a visual inspection. Post pictures here. Secondly I would advise a second look by another dealership, if at all possible. Good luck, something is definitely amiss here. |
I agree with the idea of getting a pic on here. Let everyone have a look. Perhaps the dealer is seeing something we're having a difficult time imagining? Or perhaps they're just trying to screw you. Pics would help :-)
So far, I'm leaning toward the latter. Please forgive any grammatical errors, sent from mobile |
1) there is a wear sensor that trips when its worn down 2) there's a mileage estimate that counts down i suspect its the latter that was triggered, and when they measured the pads and rotors they were still in spec. |
Pic? Ask them for a better explanation, why a rust ring is a problem. Should be entertaining - post response here! |
Sounds to me like he is asking them to replace the brakes before the car actually needs it, and that is why BMW won't pay. Seems pretty straight forward if that is the case.
2013 BMW 335xi Sedan Estoril Blue / Black Leather 6MT, M-Sport, Premium Pkg, Cold Weather Pkg, Dynamic Handling Pkg, Tech Pkg, HK Sound, M Performance Exhaust, M Performance Power Kit Former: 2011 335xi Coupe -- 2009 MCS JCW -- 2006 MZ4 -- 2002 325i -- 1997 318ti -- 1991 318i |
My guess: Someone in the back of the dealership didn't do a thorough check, then the counter guy told the OP that the rust ring means everything has to be replaced on the OP's dime. The warning light came back on because they did miss a worn sensor. Or maybe it was a brake fluid level warning and no one checked the level. Last edited by DSXMachina; 11-24-2012 at 06:54 AM. |
Sensors do occasionally malfunction and go off before the brakes are completely worn.
It's unclear if the dealer is refusing to change the pads and rotors or just the rotors. There is a spec on the rotors. If the rotors are thicker than that spec, then they do not get replaced under maintenance plan even if the pads get replaced. Most dealers (and techs) are happy to slap some pads on the car and go so they can move on to the next car.
To clarify the brake warning light - it's a two stage system: 1. At the point where the brake pads are about half worn, the first portion of the sensor is tripped. This does NOT turn on the light, but it does tell the computer. The computer then calculates (based on the mileage on the current pads) how much longer the current pads will last. Unless your driving style changes dramatically from the first half of the pad life to the second half, it's proven to be a pretty accurate way to do it. |
Good post, Tks for info.
~ 13 M3 coupe "new" daily beater ~ 13 x5M Hers - Previous BMW's - Way too many to list here (15) |
BMW dealers typically perform brake pad replacement when the light comes on (or as indicated by mileage sensor) but do not replace rotors unless defective. Of course that means the rotors eventually get tweaked and squeak, etc. However most dealers will not replace brakes under warrantly unless the car service indication shows that they are within 2000 miles of end of useful lifespan.
1993 325i - gone! 1997 328i - gone! |
Sent from my XT557 using Bimmer App |
FWIW the brake light on my 335i came on a week ago Saturday when I was about 90 miles from home. The car was already scheduled to be taken in for routine service the following Wednesday. We drove the car back home and it was fine. When I took it to BMW Manhattan they said that they rear pads were worn down and needed to be replaced. The job was done N/C under maintenance.
CA
Drivers Club at Lime Rock The Glen Club International Motor Racing Research Center BMWCCA Cayman Club Nor'Easters Madison Ave. Sports Car Driving and Chowder Society (Only a Vice President) Sports Car Club of America Polish Racing Drivers of America (PRDA) American Mural Project |
I am due in on Wednesday at BMW's invitation for oil change & brakes. Just got the yellow triangle today that said rears are worn. Never ever since 1960 have rear brakes gone out before the fronts. On average it was 2 sets of front to 1 set or rears.
Kevin 2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO 2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star 2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash |
#25
2009 335i 6MT M-Sport AW/CR Convertible & Border Collie |
