Rear Brake pads - Bimmerfest - BMW Forums
Old 01-16-2013, 08:15 AM
sandeepkarna sandeepkarna is offline
335ier...
Mein Auto: 335i 2009 AT sports model
Rear Brake pads
Hi,
I've to change my rear brake pads due in 4300 mi , do i need to go the dealer or prefer some ext known mechanic and what would be the total cost ?
Regards,
Sandeep.
Old 01-16-2013, 08:52 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
Mein Auto: '07 328iT.'13 Boxster
If you are still under the original warranty, brakes are included in covered maintenance so have your dealer handle it for free!
If not, you can have them done anywhere - cost (including rotors) from a dealer should be around $600 to $800.
Tom
Old 01-16-2013, 09:08 AM
Princeton Princeton is offline
Princeton
Mein Auto: 2008 335cxi
My parts cost $225 (purchased myself), indy labor $180, total $415.
2008 335cxi:GRAPHITE METALLIC:JADE GRAY:GRAY POPLAR:PREMIUM:SPORT:HEATED SEATS:NAV:IPOD/USB
Old 01-16-2013, 09:11 AM
335ier...
Thanks Tom, my 335 was not under original warranty but was on CPO , i dont think CPO will cover it, so would you recommend to do it any where else other than dealer??
Old 01-16-2013, 09:12 AM
335ier...
Priceton can you pleae give me the specs for 335i -09 rear brake pads??
Old 01-16-2013, 09:52 AM
Princeton
I bought Akebono Euro ceramic pads. Amazon has them, also TireRack. Just enter the specifics for your car - and the correct ones will be selected.
Old 01-16-2013, 09:53 AM
Princeton
Also, my parts included rotors. I recommend Zimmerman coated rotors as they won't stick to the wheels.
Old 01-16-2013, 10:30 AM
335ier...
http://www.amazon.com/Akebono-EUR918...1&s=automotive
here i found some would this be recommended as well also do i need to get the rotors??
Old 01-16-2013, 10:34 AM
smassey321 smassey321 is offline
Mein Auto: 09 X5d - 06 325i
I doubt you need rear rotors. Mine were still fine at 75k miles.
Old 01-16-2013, 10:49 AM
335ier...
it just had 33k on it...and showing rear brake pads change alert...
Old 01-16-2013, 10:52 AM
335ier...
the change due in 4600 mi, would that be anormal thing to change around 38k??
Old 01-16-2013, 10:56 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
In ATL Kaufmann Tire can do your brakes and will charge you a fair price compared to the dealer.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 01-16-2013, 11:07 AM
fun2drive's Avatar
BMWCCA 149159
No 33K isn't unusal for rear brakes because it depends on what driving has been done.
However I strongly suggest you go to an Indy as mentioned above and have them check the pad thickness.
The BMW pad computer isn't perfect and you might or might not need pads.
I would go with OEM pads if your car is a 2009 or older since they don't dust but if a 2007 like mine or a 2008 I would go with ceramic pads like Akebono or Cool Carbons which will not dust much but still have good brake modulation...
Old 01-16-2013, 11:10 AM
335ier...
Thanks so much.
Old 01-16-2013, 11:12 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
Stay away from the cool carbons. I have them on they are lousy.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 01-18-2013, 09:34 AM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
I'd recommend that you check out the StopTech Street Performance brake pads. They are one of the most affordable brake pads on the market, as well as having one of the most advanced stopping power. They also make replacement rotors and you can choose between blank, drilled, slotted, and drilled & slotted patterns. For those of you who actually need to do a complete brake job, you might want to also check out the StopTech stage 2 brake upgrade kit which includes rotors, pads, ss lines, and fluids for a brake job for much less vs what the dealer would charge!
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
Old 01-19-2013, 09:13 AM
rmnelson12 rmnelson12 is offline
Mein Auto: E93 09 6MT
Under the BMW Maintenance Program, when they replace the rear (or front) brake pads, do they also replace the rotors? Mine are pretty rusty around the inner wheel base
Old 01-19-2013, 03:36 PM
In the past they always replaced the rotors. Now it seems they only replace the rotors when they are below the minimum thickness.
Old 01-20-2013, 09:18 PM
dallas70 dallas70 is offline
dallas70
Mein Auto: 2006 325i
The instrument panel directed rear pad replacement a few months ago on my '06 with ~58k miles. Had it done at the dealership; also checked the rotors and they said they were still good. Cost out the door was $344 (half of that was labor). I've replaced brakes once before in my younger days; it was enough of a chore that I don't mind paying ~$175 in labor for a brake job every 50k miles.
Old 01-21-2013, 03:23 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Of no concern.
OP, this is a simple job -why not get to know your vehicle with a DIY?
It is good to acquire skill.
Old 01-28-2013, 03:16 PM
Boraxo Boraxo is offline
Mein Auto: ED 330i
I am being quoted $1100-$1200 for replacement of both front and rear brake pads and rotors. The rear are slightly cheaper. About 75% of this is for materials - looks like a good markup as the online prices are $210-240 per axel for the pads/rotors. Of course the dealer is about $100-200 more.
1993 325i - gone!
1997 328i - gone!
Old 01-28-2013, 05:12 PM
Princeton
Pads and rotors (Akebono & Zimmerman coated) can be had (335xi) for $225 an axle - delivered.
Old 01-28-2013, 07:02 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Why don't you update your "Mein Auto " to indicate that your 335i is a 2009? Then no one has to guess or ask.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 01-29-2013, 07:28 AM
335ier...
yea its 2009 335i model...
