E36 (1991 - 1999)
Old 01-29-2013, 12:33 PM
hunter94 hunter94 is online now
Mein Auto: 1993 BMW 325I
Engine Swap Questions
Are OBD-I to OBD-II swaps possible and worth it. And how about going from a M50TU to an M50 engine? Just a few questions I had because of my options on engines.
Old 01-29-2013, 12:59 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Yes.
Not really. Typically people convert their OBD-II engines to OBD-I.
Go big or go home. Get a small block V8 or an M3 engine.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 01-29-2013, 01:08 PM
Originally Posted by petriej View Post
Yes.
Yea I have seen quite a bit of posts on OBD-II to OBD-I. Well my plan is to just rebuild the m50 with stock engine components. Then once my m50tu is out I'm going to rebuild it for performance then put it back in and sell the m50.
Old 01-30-2013, 04:12 AM
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 328i, M3, 325is M-Tech
I know this is a bit off topic but somewhat related... can you use a 5 series motor in your 3 series? Like petriej said, go big or go home! LOL!
Old 01-30-2013, 08:38 AM
petriej's Avatar
The 4 and 6 cyl engines, definitely. The V8s are more of a struggle, but will fit.
GGC BMW CCA #443004
Join the BMW CCA!
Old 01-30-2013, 09:06 AM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Well aside from the V8s, the 5-Series used the same 6-cylinder engines as the 3-Series, so you're not really "going big" if you use a 2.5L or 2.8L from a 5-Series.
1998 BMW 328is
1966 Pontiac GTO
Old 01-30-2013, 11:15 AM
Unless you put the 3.0 v8 they put in the later models. But that's a whole new ball game. I'd prefer to stick around the 2.5 to 2.8 range lol. Not to mention how big of a difference would it really make?
Old 01-30-2013, 11:25 AM
petriej's Avatar
I'm not following you on that first sentence, but if you take an I6 engine from the early E39s it will be the same as the E36. M52.
GGC BMW CCA #443004
Join the BMW CCA!
Old 01-30-2013, 11:28 AM
ZeGerman's Avatar
Warm Leatherette
The 3.0L V8 was a turd. Power of an I6 with the thirst of V8. And yeah, swapping one in would be a serious PITA, as would swapping in the later 4.0L V8.
1998 BMW 328is
1966 Pontiac GTO
Old 01-30-2013, 04:33 PM
I was just saying it was possible to put the 3.0 v8 and stating it would be difficult and not worth it. Agreed, the only difference is the newer ones are OBD-II and from my understanding hard to swap into an earlier model.
Haha, that's why I'm not going to put a v8 in. Much easier to stick with the i6s. But vanos or non vanos is what I'm trying to figure out.
Old 01-30-2013, 04:36 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Buy an s50(95 m3) and just keep everything OBD1 for a good power increase for not "too" much money.
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 01-30-2013, 05:11 PM
Its hard to find s50s where I live. I can pick up a m50 for about 200 right now. And a manual transmission for 200 for a 5 speed swap. Or I can pick up a 95 325i for 800 with an engine that has cylinder problems and a manual transmission with all good exterior and interior parts and its the same color as my e36.
