Some sites say yes, like Pelican and ebay. Others no, like Summit and World Pak.
So is there one ? If so where the heck is it ???
I didn't look at the thread, but typing /TPS F3 found this which might help:
- How to diagnose and replace the TPS throttle position sensor (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
Your car has an electronic throttle control. There is a box on the accelerator pedal, and one on the throttle body. They work together, in concert with the DME, to control throttle position, based on the pedal position. The box mounted on the throttle body has an electric motor to control the throttle plate. Either module has been known to fail, and cannot be repaired, only replaced.
Why do you ask? Read mylo's post, and go here: www.realoem.com
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. Last edited by edjack; 01-29-2013 at 04:36 PM. |
Pedal has to be pushed a fair way to respond, also my idle it around 400, and the car has stalled a few times pulling into a driveway. Its an auto.
Noticed last night if my lights are on it goes up to 520ish. Car had a new battery. |
Sameo, sameo, more or less
Don't want to hijack this tread, but I have a 2000 540i and think maybe I have TPS issues. Have noted that you can't repair, just replace. My car at 74K miles, just recently have replaced plugs, O2 sensors (front), MAF and FSR (this made some difference). There is still kind of a disconnect between the pedal and the CAR. Even to the point sometimes of mild bucking. If you are really on it, meaning say 3/4 throttle, all is good. Would love to hear someone weigh in on this. I am pretty close to replacing the throttle body and see what gives. Thanks all for your input!
99-03 M62tu's have elec throttle body as edjack suggest. TSP sensor is inside. I believe there is 2 TSP sensors in it. Also as edjeck suggest you have to replace throttle body. Did one on my 540 about 2 years ago. I think it was $175ish for new one from EAC. Fixed symptoms you discribe.
Eac?
Google is your friend, and will find EAC for you.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
Eactuning.com
The electronic drive by wire throttle body has plastic gears in the servo box on the side which wear out on occaison. Remove the intake elbow and check to see if there is slop in the throttle body plate. I believe it was Justin that replaced his recently and noted better throttle response and smoother idle.
ESS Tuning m60 version software m60 intake manifold a.f.e. c.a.i. 3" obx catback full powerflex urethane setup 545 ssk cdv delete m5 rear sway bar M5 chassis rods M5 3.15 lsd Bc-r coilovers w/ swift springs Akebono=suck ss braided brake lines coming soon: Jb lwfw
If the cam shaft position sensor goes, does it always throw a code ??
If it fails, yes.
Travel seems to be a 1/8th of an inch before the resistance of the "gear" is felt. So... what is normal ? If i get a new one is there sopme new programing i have to do ? |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
