E36 (1991 - 1999)
Old 01-31-2013, 10:17 AM
Dud Dud is offline
Mein Auto: 1994 325i
The fan clutch was broken
Old 01-31-2013, 10:40 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
so no more overheating??
df
Old 01-31-2013, 10:49 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
So then the car overheats when standing still?? Auxiliary fan never kicks in?? Burrito biscuits??
Old 01-31-2013, 05:06 PM
redE36girl redE36girl is offline
Mein Auto: 1993 E36
Originally Posted by Dud View Post
I havent tried bleeding it yet i havent had the time or the weather to do it. But i just changed the oil and the thermostat. What method of bleeding would u recommend? also the heat is only working on the drivers side and at best only gets hot when i give it some gas
if you wait on the weather to bleed the system then it will continue to over heat. in turn could cause catastrophic issues.
bled the system check your coolant level frequently. it is possible to have a lot of air in this system. I have the same issue every once in a while but every time the heat start blowing cold I stop and bleed the system. its the nature of the beast.
1993 BMW 325i
1990 VW passat wagon
1987 jeep(AMC) cherokee
1979 VW westy rabbit 4 door
Old 01-31-2013, 06:00 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Although as we discovered today, the reason why you have to bleed your system regularly is because you've got a leak.
1998 BMW 328is
1966 Pontiac GTO
Old 01-31-2013, 06:59 PM
Mein Auto: 1993 E36
yep a unknown leak at that lol think its a bad expansion tank though lol.
1993 BMW 325i
Old 01-31-2013, 10:01 PM
Dud Dud is offline
I'm replacing it next week. I'm probably still going to drain the coolant or bleed the system just because it doesn't hurt haha
Old 01-31-2013, 10:22 PM
Mein Auto: 1993 E36
try to avoid draining the whole system it takes forever to bleed then.
1993 BMW 325i
Old 02-01-2013, 05:24 AM
hnaz's Avatar
BMW CCA Member
It doesn't take too long, as long as you drain the block and the radiator. You'll be fine. Might as well replace any other sensor for your cooling system as well while your coolant is drained out.
Old 02-01-2013, 05:47 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
Okay will do tomorrow. The weather ha either been in the 30's or pouring rain the last few days so ill be sure to check the oil tomorrow when I get a chance. Thanks for the help. Ill update tomorrow
Also please note the color and condition of the oil when you check it. specifically whether or not it looks like your morning coffee (with cream). That is an indication you have done severe damage to the engine. We also want to know what the oil on the dipstick looked like not just the level of it. You said you just changed it, so it should like new oil. It should be CLEAR if it is OPAQUE let us know.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 02-01-2013, 01:19 PM
Dud Dud is offline
The oil looks perfect. Just checked it out a few hours ago
Old 02-03-2013, 09:49 AM
bimmer765's Avatar
bimmer765 bimmer765 is offline
Mein Auto: 325i
Put the car up on jack stands while on a hill then turn heater on high and open the bleeder screw. One thing I do when is when i have done my coolant overhaul is fill the engine through the top radiator hose. Then I fill the radiator where the top radiator hose goes on. Then fill and bleed with the heater on high.
Sent from my GT-P5113 using Bimmer App
Old 02-17-2013, 01:08 PM
dalewilson dalewilson is offline
Mein Auto: 2005 325i
System MUST be bled properly
Just a reminder to go along with the other comments about bleeding the system: Fill system with coolant, open bleeder screw (beside rad cap) slowly fill with coolant while squeezing air out of rad hoses until there is only coolant coming out of the bleeder screw. Close bleeder, ensure rad/overflow bottle is full, PUT RAD CAP ON- very important- do not start car with rad cap off. Start vehicle, put heater on full hot/ max temp and ensure good heat is coming from vents. As said earlier, if no heat from vents, then air is still in the system.
If there is a problem with head gaskets, look for white smoke from exhaust, or look for air bubbles in overflow (coolant) bottle.
The car can overheat and the cooling fan will/may not come on if there is an air lock between the engine and the rad (area of the t-stat) as the cooling fan sensor is at the rad. and remains cool due to the air lock location. Get the air out before looking elsewhere.
25 year Master Mechanic/Journeyman Red Seal
Old 02-17-2013, 02:23 PM
HakenTT's Avatar
HakenTT HakenTT is offline
Mein Auto: '91 E30
another victim of cracked head. Combustion gas gets in the cooling system, creating air in the system that needs to be bled out every day.
Old 02-21-2013, 09:36 PM
Dud Dud is offline
Lol Nahhhh it was just the fan clutch and a crack in the thermostat housing unit. Put on a new clutch an ordered the aluminum housing unit. All is well now!
Old 02-24-2013, 09:32 AM
bimmer765's Avatar
Mein Auto: 325i
Those Behr fan clutches are junk. When I bought my E36 with 156k it had probably been bad for years. Then went I bought my E46 with 79k last summer of course the same damn Behr fan clutch was shot. For some reason the seals go bad and they leak out all the oil. I replaced mine with BorgeWarner clutches no failures so far. On my E36 I replaced the t-stat housing with an aluminum part. The E46 I had to go OEM plastic since its all built in.
Sent from my SCH-R760 using Bimmer App
Old 02-24-2013, 09:44 AM
hornhospital's Avatar
D'oh, You Kids!
Behr is OEM. Typically lasts 150k+. Definitely not junk.
Quotes to live by:
Old 02-24-2013, 09:52 AM
bimmer765's Avatar
Mein Auto: 325i
A fan clutch should last more than 70k. Ive replaced every Behr part on my E36. When my radiator blew last summer it was the original Behr then I tried a Nissens that started leaking a month later. So I went back to a Behr no leaks so far.
Old 02-11-2015, 12:57 PM
mackadelics_325 mackadelics_325 is offline
Mein Auto:
Originally Posted by ZeGerman View Post
One thing you should know right off the bat is that if all other components in the cooling system are working correctly, the electric auxiliary fan should not even need to come on unless you have the A/C turned on, or are driving through Death Valley in August. What that means is that the fact that yours isn't turning on at all is only one part of your problem. Yes, it should turn on if the coolant temp goes beyond the threshold at which the belt-driven fan can no longer adequately cool the engine, but if everything is working correctly, it should rarely (if ever) get that hot in the first place. Your aux fan probably has a bad relay or fuse, so you'll certainly want to fix that. Once that is dealt with, you'll want to figure out exactly why it's getting so hot in the first place.
How many times did you attempt to bleed air out of the system, and which method did you use? Are you getting hot air out of the vents inside of the cabin?
Hey don't run it anymore man, get it figured out I had the same problem. Had to replace the thermostat and water pump. Check your fluid levels for your colant and bleed your radiator. Before you blow a head gasket or warp, and possibly crack your head. Maybe your radiator is plugged up. Anything that has to do with coolant system replace it. I just bought a 94 325is blown head gasket cracked radiator, bad water pump, thermostat. Engine still sounds beautiful. I gotta flush my engine, as bad as it sounds I'm gonna a flush it with a bit of diesel, before the antifreeze in my oil kills my engine...
Old 02-11-2015, 01:02 PM
Mein Auto:
Old 02-11-2015, 01:05 PM
Mein Auto:
Yeah if you got air pockets in your coolant system. Bleed it until it's completely full to get them air pockets out
Old 02-11-2015, 01:07 PM
Mein Auto:
I have a question myself, my thermostat was stuck closed and ultimately would affects my heater core right ?
Old 02-11-2015, 02:20 PM
D'oh, You Kids!
It'd make it really hot, right up until the head gasket blows.
Quotes to live by:
Old 02-11-2015, 02:50 PM
Mein Auto:
Me?
Old 02-11-2015, 02:51 PM
Mein Auto:
I replaced the thermostat n my colant system works fine now
