Do-It-Yourself H.Q.
Old 01-30-2013, 09:19 AM
squeaky3 squeaky3 is offline
Mein Auto: nothing
03 bmw 330xi hesitates on take off
im working on a bmw for a customer, originally came in for no start and smokes badly, searched around here and other places and found the ccv system at fault, so removed the intake replaced the ccv system and hoses (except hose to dipstick from bottom of valve)
also replaced spark plugs and valve cover gasket
now car has a hesitation when you take off from a stop, driving down the road car drives great, but when leaving a stop it hesitates for a second then takes off, sometimes it will even hesitate enough to kill the engine
first thing was checked fuel pressure, has constant 35 psi at all times
could a vacuum line have gotten switched around or swapped and cause that or am i looking for something else?
Old 01-30-2013, 10:01 AM
Mein Auto: nothing
well nevermind, found a connector not plugged into that "wirebox" that box with the wires and hoses coming off of it under the intake
plugged that in and drives just fine now
