Old 01-29-2013, 08:43 PM
navyjetmech navyjetmech is offline
Mein Auto: Harley/Z4 3.0/Ram 1500
Soundplicity IPOD Intergration
I purchased a Soundplicity Iphone Intergration kit from Bavarian Soundwerks. It was VERY easy to install took me about 45 min. . It sounds great ,no static or interference of any kind. I can control song selection via the forward and backward buttons on the stereo. I also ordered a DSP adapter but I did NOT end up needing it, I am in the process of returning it. It also charges my Iphone. I have a 2003 z4 with business stereo, DSP feature and Navigation the kit did not interfere with any of those functions. I have enclosed links for a you tube video that walks you through the install.
Like I said soooo easy a monkey could do it.
Old 03-27-2013, 06:26 AM
AB1945 AB1945 is offline
Mein Auto: '01 Z3 & '02 325i Wagon
I put the soundplicity iPod integrator in our 325i wagon last year. Just ordered another for the Z3 we just bought. Great sound and easy to install.
Old 03-27-2013, 07:19 AM
LarkHouston's Avatar
LarkHouston LarkHouston is offline
Doing the best I can
Mein Auto: 2013 Porsche Boxster S
I. unfortunately. am not having as good luck as you. In fact, the car is currently at a local sound shop trying to sort out the problems. Install is easy enough, however, the problem is that it will not stay connected. Plays for various periods of time and then disconnects on its own. Don't know if it is a problem with my radio, with the BSW device or what. I will update when we figure out the problem.
2015 Audi SQ5
Recent Past:
2009 335i Coupe Dinan S3
2006 BMW Z4
Old 03-27-2013, 10:41 AM
Google "ipod cuts out in car". It doesn't seem to be an uncommon problem - there is a possibility the ipod will cut out any time there is a variation in voltage. Have you checked with BSW as it sounds like something they may have dealt with before. Good luck with it.
Old 03-27-2013, 11:59 AM
Yes, the sound shop is supposed to be conversing directly with BSW.
2015 Audi SQ5
Recent Past:
2006 BMW Z4
Old 04-04-2013, 02:10 PM
Update: BSW said to unplug the Soundplicity, allow the capacitors to fully dissapate, and reconnect. Problem fixed for now. But I've just had the car back for a day. I will be interested to see if that fixes the problem on a long term basis or whether the problem returns. Because unplugging is not exactly a simple thing to do. Have to remove trunk lining, put my fat head and fat fingers in odd positions and then wait for a while and then put it all back together. I'll update again in a few weeks if it seems to be a permanent fix, sooner if not.
2015 Audi SQ5
Recent Past:
2006 BMW Z4
Old 04-30-2013, 08:55 AM
silverfoxy silverfoxy is offline
Send a message via Yahoo to silverfoxy
Mein Auto: 00 328ci, 10 135i
LarkHouston how did this fix work for you? We are having the same problem in our Z4.
Because I deserve the best!!!!!!
Old 02-10-2014, 03:34 PM
z4lover z4lover is offline
Mein Auto: z4
I would not suggest to use Soundplicity at all. The Bavsound just changed its name from DICE/Mediabridge. It causes you sound problems soon or later. I don't want to see another victim.
Old 02-10-2014, 08:12 PM
I have had mine installed for about a year still no problems.
Old 02-11-2014, 09:52 AM
rmjames007 rmjames007 is offline
Mein Auto: 2009 135i
I have the same model and have had no problems. I actually want to upgrade to the one that has bluetooth
