Old 01-30-2013, 05:49 AM
coy coy is offline
Mein Auto: 2000 M Roadster
Car will not start
All,
2000 Z3 M version. Has been sitting for a while and now went I try to start it I get nothing. No lights on the dash, not attempt to engage the starter, no radio, no taillights, no head lights. I have 12 volts at the Jump point under the hood and at the Fuse Box.
What works is the power seat, the interior lights, the trunk light, the key chime and a security light on the radio. The Battery is about 1 1/2 years old and I have had it tested at 2 places. I have charged it and I have tried a jump start with no success
This happened one other time and cleared on it own.
Two questions,
What are the sysptoms of the EWS system when it is engaged?
Could it have something to do with the key or key fob?
Where do I need to go form here? Any ideas or thoughts much appreciated!
Coy
Old 01-30-2013, 07:39 AM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
Do you have an alarm that may still be triggered?
Old 01-30-2013, 11:05 AM
coy coy is offline
None that I am aware of
Old 01-30-2013, 04:17 PM
Z3Papa Z3Papa is offline
Mein Auto: 2002 Z3 3.0
Mine is in the same condition as yours. I've put two different batteries in after full charge and can not get the car to turn over. I think it is either the alternator or the starter but am subscribed. I was having a charge down which I thought was from a fault door sensor or actuator. Right now the car is not needed as it is not my daily driver but race season is coming in 8 weeks so something is going to be done to address the issue.
2011 BMW M3 ZCP in Melbourne Red, Apex wheels (ARC-8 and EC-7's) with Bridgestone RE-71R's.
Old 01-31-2013, 01:04 PM
coy coy is offline
Z3Papa, do any of the lights come on, oil, air bag, seat belt, etc when you turn the iginition switch to the "ON" position? Mine doesn't.
Coy
Old 01-31-2013, 02:33 PM
flossy21 flossy21 is offline
Mein Auto: Ford Explorer
Pull the Codes
Have you pulled the codes to see if that provides any further info?
Old 02-01-2013, 07:53 AM
Coy
yes, they all come on in the on position strong but car just clicks.
Old 02-01-2013, 01:57 PM
coy coy is offline
The car doesn't appear to have any power but I'll have to check, good idea, thanks
Old 02-04-2013, 07:43 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
If the lights come on, but you just get clicks, in my experience that is a bad battery. May need a charge, or you may need a new one.
Check the battery voltage while you try to crank. It will probably drop VERY low.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 02-06-2013, 05:25 PM
I'm embarrassed to admit you were right. Both my regular and Deka lightweight batteries appeared to take a full charge from my battery charger but neither would start the car. Bought a new battery and the car fired right up. I suspect I have a slow drain which I suspect is from a faulty door or trunk actuator as my remote entry is having little issues as well. I'll keep the car on a battery tender and get it sorted out but thanks for the input.
Old 02-07-2013, 07:25 AM
Pinecone's Avatar
M Mad
Glad I could help.
These cars have small drains for various things, like the remote entry must have to power to "listen" for a signal.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 02-07-2013, 11:22 AM
coy coy is offline
OK,
Back to my problem. I get absolutely NOTHING when I turn the ignition switch to the on position. No lights, no clicks, no radio. Again what DOES work is the power seat, the clock, the key in the ignition door open chime, the passenger compartment overhead light and the trunk light.
Any thoughts?????
Coy
Old 02-24-2013, 06:50 PM
raywith76elsi raywith76elsi is offline
Mein Auto: Z3 Roadster
Have a 2000 Z3 that is experiencing similar problem. Code reader indicates that EWS is locking out the starter; something about engine speed signal. End result is the car lights up (until battery went dead from sitting) but starter will not turn.
