6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
Headlamp adaptive controller
I have had the adaptive headlamp failure for quite some time now, drivers lamp does not self test and adaptive turning does not work, when I purchased the car this was a problem and was told it needed a new stepper motor, I have since removed the lamp and done the 1mm hole drain mod which by the way worked a treat! I removed the controller unit and it was full of creamy gunge, the question is does a new controller need to be coded or is it p n p? I have heard it to be both! I am looking to replace in the next couple of weeks.
I Love LA. It lets me ride in the winter with the top down. 07' E64/Black....12' F10/White |
Did u have to pull the bumper?
Yes but not a hard job, the controller is located on the side of the lamp unit, you may get away with just lowering the bumper.
No light it's the side, no movement it's the bottom unit. You might also need a bulb and an igniter.
I swapped the ignitors and they worked, I have no light but don't know about the movement.
Where would it be the best place to get these parts?
Tisher. They have been great for me. If you are in a hurry many dealers will match prices. Others will rip you off. Do your homework.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
