Must the aux/electric fan always run when AC is on?
2000 528iA
1.) Installed Dynavin D99 2.) AC Stopped engaging (compressor does not turn on) 3.) Removed D99 and updated firmware on ibus module of Dynavin 4.) AC still not engaging - HVAC module needs to be re-coded per Jeff (Dynavin) 5.) Connected to GT1 and somehow got it to write re-code the HVAC Module 6.) AC works fine now Butttt the aux fan does not turn on. I ran a test from the DME module and it spun up fine, so I know it works fine, but it wont turn on when the AC is on. At what point should that fan turn on? Should I be worried that's it's not turning on when the compressor kicks on? FWIW I had the AC on for 20 min idling - never spun up once - I was monitoring Oil/Coolant/Engine temps and they were right where they needed to be - So maybe that's why fan did not turn on? Last edited by kgorczyn; 01-30-2013 at 07:29 PM. |
The aux fan on the early cars ran all the while the A/C was on. Later cars were smarter.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
Mine does not. 98 528
Either you are part of the solution, or you are part of the problem. |
aux fan does turn on on my 2000 528
Mine only comes on when the control module determines that it is needed not when the AC is turned on necessarily. Check the sensor in the bottom radiator hose. If mine is unplugged the fan runs all of the time regardless of the AC being on or not.
Awesome tip - I'll give it a shot - Thank you!
M62TU/M52TU/M54 Aux Fan Info
The M52 & M62 aux fans' operated differently than the M52TU/M62TU/M54 aux fans. See the info below for the latter:
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
What a lesson. Thank you gentlemen! Puts me at ease! Very valuable Info!
Mine only comes on when I have the "MAX AC" button on. It works great. But normally I have the a/c in Auto, 72 or 73. So it doesn't work very hard unless it's summer.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going. Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, HKS Exhaust, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
