E60 (2004 - 2010)
Old 01-30-2013, 10:33 PM
marsel marsel is offline
Mein Auto: e60 550i sport
Do you know if a larger than stock tire will fit the 550i sport?
Wanted to hear from some of the experienced members here if I have any options for a larger-than-stock tire size with the wheels I just picked up?
I have an 08 550i sport and am running the staggered stock sport wheels and tires;
Fronts: 8.5x19 wheels and 245x35R19 tires
Rears: 9.5x19 wheel and 275x30R19 tires
Not certain of the OEM stock sport wheel offsets?
I just picked up some BC Forged wheels with the following specs:
Fronts: 9x19, +15 offset
Rears: 10x19, +25 offset
Now, my question is: Must I get the same exact size tires or can I possibly fit a larger tire without any rubbing to give it a slightly more aggressive look like an M5?
Please let me know your experience, advise, suggestions and/or opinions. Thanks!!
Old 01-31-2013, 04:55 AM
E60black E60black is offline
Mein Auto: 545i
You can use the stock tires for the new wheels, it'll just stretch the tire tad bit more. Less rim protection if anything.
Old 01-31-2013, 07:04 AM
GOR777's Avatar
GOR777 GOR777 is offline
Mein Auto: 2007 BMW 550I
sure you can run the same tires, or you can go wider like 295 at the rear but the front keep it at 245,
I run 255/40/19 at the front and it rubs a little at the bumps, and 285/35/19 at the back and its perfectly fine
So if you have to buy new tires get 245/35/19 at the front and 295/30/19 at the back and it will look very nice ( not sure if 255/35/19 will be ok for the front)
http://tinypic.com/r/vwzua1/6
Old 01-31-2013, 07:06 AM
HPIA4v2 HPIA4v2 is online now
Mein Auto: E53, E60, E92
The 550i sport stock wheels are 18 Front and 32 Rear offsets
so you basically adding half inch of width that will be distributed to 3mm to the inside and 9mm to the outside in the front.
In the rear, you are putting most of the extra half and inch to the outside (about 14mm).
I think you'll be OK, the easiest to try is to put masking tape across the fender well and see how much clearance you have between the wheels to the masking tape on the stock wheels. The question is are you dropping/slamm the car with aftermarket suspension?
Old 01-31-2013, 07:58 AM
Right, but my interest is putting more rubber on the wheel for performance rather than stretching a tire for aesthetics.
Old 01-31-2013, 08:05 AM
I like the idea of the larger rear, I just hope it doesn't stick too far out from the body? I think I may just have to find someone with this model 550 running the same spec wheels to know for sure if they will fit? I will probably pick up some Pilot Supersports for these wheels.
Old 01-31-2013, 08:20 AM
Thanks for the offset info - couldn't find it. I'm trying to make everything I do to this e60 more performance based and tasteful rather than for aesthetics or a hot rod car show. That said, I may put on a KW V2 suspension in the future. For now, I'm leaving the stock suspension and do plan on a relatively easy couple track days (I used to beat on some older track cars but have become much more risk averse).
I was just thinking it would be nice to have a bit more side wall than what it has now with the stock wheels. The wheels I just picked up are a half inch wider which seems like I am going in the opposite direction than I want to if I cannot put either a wider or taller tire on it.
