Go Back   Bimmerfest - BMW Forums > Welcome to Bimmerfest > New Member Introductions
Welcome to Bimmerfest! Whether you are a current BMW owner or just interested in BMW cars, we hope you enjoy your visit. Take a moment to introduce yourself and post a picture of your BMW for the rest of the community to see.
Old 01-31-2013, 07:01 AM
Sean680805 Sean680805 is offline
Mein Auto: 2001 BMW X5 4.4i
Self Leveling Suspention
Hi All, I purchased a 2001 X5 4.4i three months back. I noticed that the rear of the vehicle was lower than the front but appeared to drive fine. Three days ago I pulled away a bit faster than usual. "Self Levelig Suspention" appeared on the cluster. I pulled over switched the vehicle off, started again and after a few minutes the warning re appeared. I have not heard any pump or noticed any variation in ride hight since purchasing the vehicle. Could anyone please advise as to where I should start to fix this problem.
Many thanks Sean
Old 01-31-2013, 09:45 AM
bmwoem1 bmwoem1 is offline
Regional Sponsor
Mein Auto: X3
The most common problem is leaking air springs. The usually crack over time. You can spray soapy water around the whole air spring and look for bubbles. If you are certain they are not leaking, you may have a failing ehc compressor, or in rare cases and bad ehc control module. Someone with a bmw scan tool should check for faults
