Old 01-31-2013, 03:03 PM
dels auto dels auto is offline
Mein Auto: 528i
Code 27
HAVE A 528i WENT INTO LIMP MODE HAS CODE 27 SERVOMOTOR ELECTRICALLY FAULTY. ANY HELP WOULD BE APPRECIATED AS WE HAVE LIMITED ACCESS TO BMW MANUALS
Old 01-31-2013, 04:01 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
HELP! MY TYPEWRITER IS BROKEN! E. E. CUMMINGS
What model year is your car?
27 = Idle control valve closing coil
Output digital pulse width (active low)
DME final stage will set flag whenever a short to ground, a short to battery voltage or a disconnection
between output transistor and component exists.
I'm sure you can get a Bentley manual through Customs, n'est-ce pas?
Old 01-31-2013, 04:25 PM
Mein Auto: 528i
Originally Posted by edjack View Post
help! My typewriter is broken! E. E. Cummings
what model year is your car?
27 = idle control valve closing coil
output digital pulse width (active low)
dme final stage will set flag whenever a short to ground, a short to battery voltage or a disconnection
I'm sure you can get a bentley manual through customs, n'est-ce pas?
it is a 1997
Old 01-31-2013, 04:26 PM
Mein Auto: 528i
1997 528i thanks. I failed to mention that I am scanning through the 20 pin access. looking at the abs system which had a R.F speed sensor problem. but I am left with a code 27 servomotor electrically faulty. (reading now on scanner).
