Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 01-31-2013, 04:01 PM
525isport's Avatar
525isport 525isport is offline
Mein Auto: 2003 e39 525i sport (uk)
735i will not start please help
Hi every one im usually in the E39 area but my dad has bought a 2001 735i sport model (same as the 740i ) V8 engine . but we cant get it started . the car was working fine untill the engine and transmission along with the suspension and wiring was removed from the car for repairs to the body to be done and now ,after four months we put everything back together ,the car will start for one or two seconds and then die and im getting engine failsafe and four codes
P0120 throttle / pedal position sensor A circuit pending
P0123 throttle / pedal position sensor A circuit high input pending
P0223 throttle / pedal position sensor / switch B circuit high input
P0103 mass or volume air flow circuit high input pending
the first three CANNOT clear with my Actron cp9580 scanner ,but the last one will clear and return after the first attempt to start .
i have done alot of searching and found similar problems ,i have looked for corrosion at the temp sensor on the thermostat (none ) checked and rechecked the connections at the dme and all other wiring . any help in this matter will be great
2003 525i sport uk import .see pic ^
1997 300 Tdi Landrover Defender
Old 01-31-2013, 04:05 PM
Geodeleo Geodeleo is offline
Mein Auto: 2008 X3 M Sport
Bhfftyugbghzjyyyyyyduxdzjamjanjzyxygzgzggzvzusgxyr vsvsssvs. As s sesvsvshhhsshshshshhshyssyzvbsbaushush
Old 01-31-2013, 04:23 PM
525isport's Avatar
thanks i will check that right now
HTML code is Off
