BMW 325i sedan e46 2002 doesn't start - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-31-2013, 06:09 PM
dman79 dman79 is offline
Mein Auto: 2002 325i sedan e46 BMW
Unhappy BMW 325i sedan e46 2002 doesn't start
Please help guys. I have a 2002 BMW 325i sedan e46 that used to start before I changed the trunk completely. The only thing that was changed during the process was the battery and the charcoil Canister. After the changes, the thing would start but run for like a second and then would die. Thanks for your time
Old 02-02-2013, 06:16 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
get this started yet?
Old 02-03-2013, 03:11 PM
No i haven't gotten it started it yet. But additional info the charcoil canister was used. (If it makes any difference.
Old 02-05-2013, 10:43 PM
Update
I was able to start it by spraying starting fluid into the BMW. But no other way
Old 02-05-2013, 11:36 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
When you turn the key to Position 2, do you hear the "whirring" sound of the fuel pump priming the system ?
The road goes ever onward....
(R.I.P. Jever)
Old 02-06-2013, 10:16 AM
Yes the Fuel pump is making some kind of sound during the starting process.
Old 02-06-2013, 10:54 AM
Fast Bob's Avatar
Keeping it surreal
If you got a response when using starting ether, that would probably indicate a fuel delivery problem. Check for pressure at the fuel rail.
(R.I.P. Jever)
Old 02-06-2013, 11:16 AM
Okay will check in the evening. Where is it located?
Old 02-13-2013, 12:39 PM
Update. I did some research and checked if my MAF is bad. After unplugging it the car started and I could rev it. Could this be the problem? waiting for the fuel pressure gauge to arrive
325i, e46
