Howto test abs pressure sensor? - Bimmerfest - BMW Forums
Old 02-01-2013, 08:23 AM
chuckjim chuckjim is offline
Mein Auto: 2000 528i
OK so just a bit of background. I have a 2000 528i with 140k and trifecta abs lights on and off speradically. Replaced faulty right front wheel sensor and still having issues. I have an OBDII tester that I think is giving me a 15 fault code which could be ABS pressure sensor? What is easy way to test sensor? I have multi meter. Do I test sensor or plug going into sensor? If plug in then do I use paper clip to stab into connector? I know Im testing voltage and it should be 0 volts at rest with ignition to on but not running and 0-5v with firm pressure applied to brake. Anything else?
Old 02-01-2013, 08:31 AM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
My faulty right front sensor shorted and fried my ABS module so replacing the sensor wouldn't help if the same happened to yours.
Try a search of the best links, I know Bluebee has covered this.
Old 02-01-2013, 10:36 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
In another recent thread of yours on this topic), I already pointed you to the following thread:
- How to test the BMW E39 Brake Pressure Sensor
It's best to add your information there so that we can keep it all together (to help the next person thereafter).
Old 02-01-2013, 01:42 PM
Thanks Bluebee. Sorry for starting a new post but very frustrated with this. today the lights have come on and gone off about 3 times. I notice when lights off it seems abs engages under very minimal wheel slippage?
Old 02-01-2013, 04:53 PM
no voltage at abs pressure sensor
I am not getting any voltage reading at abs pressure sensor. When I check voltage from white/blue wire going into pressure sensor connector(stripped bit of insulation away) I don't get any voltage and none when brakes applied either?
Old 02-01-2013, 04:54 PM
could I have a bad ground wire since not getting any voltage?
