5 Series DIY
Old 10-29-2007, 07:39 PM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
DIY - Fan Clutch Nut Installation
Just replaced my defective "MTC" Fan Blade.
Those of you who have replaced water pump or done the cooling overhaul know it is a PITA to install the Fan Clutch onto the WP Hub: the space is tight, the thin 32-mm wrench does not have much room to move etc and etc. Sometimes it can take up to 15 minutes to thread this stupid 32-mm Nut.
Well, I just came up with this trick that makes the Fan Clutch Nut Install in 10 seconds! It was a breeze!
- Remember that this NUT is reverse thread, so turn it Counter-Clockwise to tighten it.
- Get a short section of a poultry cord (dental floss or shoe lace is also OK)
- Use a small piece of masking tape to tape one end of the cord onto the NUT.
- Wrap the cord around the 32-mm Nut 3-4 times in such a way that when you pull the cord, the NUT turns CCW (Viewed from FRONT of car)....See Picture.
- Apply a bit of grease or antiseize on the 32-mm Nut to make install easy (also making future removal easy).
- Hold the Fan Clutch snugly against the WP Hub, then Pull the cord upward. This will turn the NUT CCW. No need to tighten the nut. Engine rotation will tighten it.
Install takes less than 10 seconds!
HTH.
Old 10-29-2007, 07:45 PM
jvcajita's Avatar
jvcajita jvcajita is offline
e39 m5 touring aspirant
Send a message via AIM to jvcajita Send a message via MSN to jvcajita Send a message via Yahoo to jvcajita
Mein Auto: LSB WB 540 Touring VF S/C
ingenious! i'll do that next time. gonna put it on as a bookmark!
Old 10-29-2007, 07:46 PM
djfitter's Avatar
djfitter djfitter is offline
Mein Auto: BMW '08 535i
I don't need this advice, but I like it.
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 10-29-2007, 07:59 PM
My advice is always free...hehe....
Old 10-29-2007, 08:56 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
slick... i would just put it on when the car is running..... NOT.
americandan.com
It takes a lot of work to be lazy.
Old 10-29-2007, 11:15 PM
325ic a beer's Avatar
325ic a beer 325ic a beer is offline
World Traveller Forever
Mein Auto: 1992 BMW 325ic M Technic
yeah...
Heh he heh ehheheeh funny stuff!
325ic a beer
"Swimming with the sharks" All over this World...I'll see you in the next one.,,yeahhhh.... AND DON"T BE LATE,,,, DON"T BE LAAATTEE!
Old 10-30-2007, 06:51 AM
Buy $1M life insurance before doing that chivas...hehehe...
Old 10-30-2007, 06:59 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
That's great! Don't pull too hard, you might start it.
Take my advice, I'm not using it.
bimmerd00d's Avatar
bimmerd00d bimmerd00d is offline
just havin a heart attack
Send a message via AIM to bimmerd00d Send a message via MSN to bimmerd00d Send a message via Yahoo to bimmerd00d
Mein Auto: 1998 540i 6-speed
If your fan clutch is in proper working order, just spin the blades and the nut tightens 90%. The last 10% i use a 32mm wrench and a rubber mallet.
(as of 11/18/11)
2004 Volvo S60R - The new ride!
1998 540i 6-spd. - Sold!
2000 528iA sport - Mom's ride, 308k!!!! and still drives like new
2005 Dodge Ram 2500 Cummins - 145k, 800lb/ft. John Coal Train.
2001 Volvo C70 Coupe T5 - The wife's car, 170k. Needs a timing belt soon
Old 10-30-2007, 07:15 AM
bimmerd00d, that is not the issue: the issue is how to start the first thread of the stupid NUT!!!! Once it starts to catch the 1st thread in, you spin until it stops. The engine rotation will tighten it.
Old 10-30-2007, 07:26 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Thanks Cn90--When I was opening the thread ,I started to wonder if it was possible to tie a piece of cord on and make it do the trick--will be useing this in the next couple of weeks.
I was just imagining how difficult putting the fan back on was going to be-no room and all
The fan will sit on the hub I understand and with the rope trick I can see this greatly aiding the rebuild.
Old 10-30-2007, 07:33 AM
Yeah, some people spend up to 30 min to thread the 32-mm nut in, after some "nice" language like "wtf" it will go in. This is because the space is so tight, unless you have small child hands, it is very difficult to catch the 1st thread...Been there done that...
Old 10-30-2007, 07:49 AM
2slow4u's Avatar
2slow4u 2slow4u is offline
Mein Auto: 528i
Very clever, but sense my both belts snapped last week and left me stranded on the side of the beach...the easiest way I found to put the fan back on was to hold the fan so that the nut was pushed up against the bolt and have my buddy give the car a real quick crank(not start the car) on the ignition.
Old 10-30-2007, 08:32 AM
drbeck drbeck is offline
Mein Auto: 2002 530I, 1992 325I
Another option is to go from the bottom and thread the nut on. The fan shroud has larger gap on the bottom that makes it quite easy to reach your hand up and start the threads.
Old 10-30-2007, 08:44 AM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 2000, 1995 540iA, 07 525
Or you could just give up and weld it on.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 10-30-2007, 08:56 AM
ross1's Avatar
Would you be offended if I took a life insurance policy on you?
Old 10-30-2007, 09:40 AM
bmwm3coupe bmwm3coupe is offline
Mein Auto: 2000 540iA
Very clever!
William
'00 540iA (mine)
'05 330iA (hers)
Old 10-30-2007, 10:47 AM
bimmerd00d's Avatar
OH, yeah that's a pain in the buttocks (forrest gump).
(as of 11/18/11)
Old 10-31-2007, 02:20 PM
e39dream's Avatar
e39dream e39dream is offline
L C B
Mein Auto: 1998 528i sport, DOB 5/28
good tip- getting the thing started is the hard part, at least for me.
Old 09-19-2008, 08:40 AM
Eric528i Eric528i is offline
Mein Auto: BMW 528i
Fan clutch
I am getting ready to replace mine this weekend on my 528i and can't thank you enough for the tip before I get started.
Old 01-19-2009, 06:13 AM
xWulfgar xWulfgar is offline
BMW ***** since 1993
Send a message via AIM to xWulfgar
Mein Auto: 2011 328i xDrive
Thumbs up
Good job.
_______________________________________________
Chuck T.
a.k.a. xWulfgar
Old 05-23-2009, 07:44 PM
Lbert Lbert is offline
Mein Auto: 325i
Great idea!
Old 07-30-2010, 01:10 PM
Does anyone know the TAP size to clean the threads on the water pump shaft?
I didn't know about this wonderful trick until it was too late.
The last thread or two of my water pump shaft is "sharp" to the touch, such that the fan nut is going on crookedly (details here and here).
I'll bet this next question has never been asked on Bimmerfest before ... but I need to know ...
Q: Do you know what the tap size is for the water pump shaft threads?
BTW: Below is a pictorial DIY of cn90's suggested method. It failed for me, but, only because I had already stripped the last thread or two of the water pump shaft NOT using this method!
Old 09-04-2010, 02:15 PM
Vike3 Vike3 is offline
Mein Auto: 2002 530 Sport
That's awesome. I just did the full cooling overhaul and they say the first step
and the last step (dealing with that hex nut) are the hardest. They turned out
to be the easiet thanks to that trick. I used kite string and duct tape.
now I just gotta deal with air in the system. Everytime no matter what I try
I always get it.
Old 09-05-2010, 09:16 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
I was amazed I guess or maybe just lucky but I was able to just grip the fan on both side and spin it right on the nut to start it*...then I just spun the fan to tighten it as much as possible and threw the 1 1/4" wrench on it to tighten it a tad more. Just let the engine to the rest over time.
* - Okay, I tried doing it from above for a few mins...then below for a few mins...then I was going to try the string trick and decided to try it from above again and son of a gun, spun the sucker right on. Lucky me.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles)
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have)
