E34 (1989 - 1995)
Old 02-26-2013, 05:41 PM
Ena01 Ena01 is offline
Mein Auto: 525i and 325is
1995 525i Alternator won't charge correctly
Ok, replaced the computer for the 525i since it wouldnt start now it starts. But now it wont run on the alternator? It only runs on the battery, i have changed the alternator 2 times!!! and still it will not charge right. I think it might be burning them I dont know why. I try the stomp test and it wont work neither. I know who to do it since i have done it on my brothers 325is. Please i need any tips.
Old 02-26-2013, 11:30 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
is the cable connected etc? inspect grounding straps.
also is the alternator you replaced it with a rebuilt item or just out of a wreckers yard?
E30 above Sold
Last updated 2nd January 2014
Old 02-27-2013, 07:14 AM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
FIRST IDEA IN MY HEAD - some alternators come with a PIN OR TAB that once removed the brushes then will touch the stator (via spring) and the alternator then is ACTIVE.. this tab is supossed to be removed before install.. USUALLY RED AND ON THE BACK OR SDE!
other than that, 1 st check fuses and fused links ( aka ground straps), positive post on alternator.. and its connectors..
if it comes out agian test it and maybe the old part 2.. make sure you are working with know GOOD PARTS..
2nd make sure your battery is chargeable.. WHAT IF, your alternator worked but your battery so dead i'ts just killing the new alternator?
USE A DMM to check voltage output and let me know.
THE VOLTAGE REGULATOR MONITORS THE BATTERY VOLTAGE AND WILL SWITCH THE ALTERNATOR ON & OFF TO MANTAN 12.8V AS NEEDED..
IF INSTALLED AND ASSEMBLED PROPERLY, THIS SHOULD BE THE PART NOT DOING ITS JOB.. (inside alternator)
a ECU has no affect on charging i believe.. all the V regulator i think.. anyone back this up???
Old 02-27-2013, 10:04 AM
the first one was a rebuilt i bought and the other one as well from autozone.
Old 02-27-2013, 10:17 AM
ok, where do i find the ground straps?
Old 02-27-2013, 10:23 AM
Resident e34 Racer
Exclamation just 2 be clear..
you do remember removing the brush retainer pin before install??
Old 02-27-2013, 10:44 AM
it didn't bring a pin on the side.
