Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 02-01-2013, 04:10 PM
Kevin Halbleib Kevin Halbleib is offline
Mein Auto: 740il
1995 740IL radio and other electrical issues
I just purchased a 1995 BMW and have several electrical issues.
1. Radio not even coming on. Seems to be no power. I did check the fuse under the hood on the passenger side. Looked good.
2. Blinkers work. However on the cluster it does not show up. Hazards as well. Work on outside but not on the cluster. (speedometer on cluster does not work either, but tachometer does. Cluster does light up fine.
Any advice would be appreciated.
Old 04-01-2013, 12:01 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 BMW 325i Convertible
Check the fuses in the trunk above the battery. Primary for radio fuse is there
HTML code is Off
