Old 02-01-2013, 08:59 PM
GabesJH82 GabesJH82 is offline
Mein Auto: 2002 BMW 530i
Best obd2 scanner?
Looking for a decent scanner that can read most of the trouble codes for example abs srs pcm what do ya recommend for bmw
Old 02-01-2013, 10:00 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
autel maxidas does a decent job for average home mechanic
Sent from my Nexus 7 using Bimmer App
Old 02-01-2013, 10:02 PM
I use to have this scanner but had to get rid of it since it didn't do the work I need
Old 02-01-2013, 10:04 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Making sense of the most often recommended BMW diagnostic tools & cable interfaces (1) & BMW factory & dealer programming, coding, and diagnostic software such as INPA, EDIABAS, NCS Expert, DIS, EasyDIS, Progman (1) (2) (3) (4) (5) (6) (7) (8) (9) & related BMW diagnostic-tool forums (1) (2) (3) (4) (5)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 02-01-2013, 11:13 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
How much money do you want to spend? If less than $100, fuhgedaboutit.
If you want a full-blown scan tool, consider a Snapon with the BMW package.
Old 02-02-2013, 12:39 AM
IkeRay IkeRay is offline
Mein Auto: 1997 BMW 528i (white)
you're not going to read ABS codes with an OBDII scanner.
as BlueBee pointed out, there are LOTS of options, most of them pricey. I've fooled around with it a lot, but I finally have CarSoft 6.1.4 (6.1 service pack 4) working with VagCom409.1 (ebay) + 20pin can. It was worth it to me because I didn't have the funds for an expensive means, but it was in no way easy to get to work.
Old 02-02-2013, 04:54 AM
bmwmanz2 bmwmanz2 is offline
Send a message via MSN to bmwmanz2 Send a message via Yahoo to bmwmanz2
Mein Auto: E39 528i
How much does one of these run? Also, I have the Peake fcx3-u tool '87-'07 that I am thoroughly happy with.
-Tony
Old 02-02-2013, 08:01 AM
bluebee's Avatar
Agreed. In fact, read Bill's posts on why almost NO tool is correctly reporting ABS issues:
- Bill's 'logic' of testing ABS sensors
This is just my personal take on software/hardware ... but ... what I do is use the free stuff first, and then, if the free stuff fails me, then (and only then), I bother with the paid for stuff.
The advantage of this method is that you KNOW what you want and need by the time you get to pulling the money out - and - often you don't have to.
The disadvantage is that it takes effort. Often lots of effort.
Old 02-02-2013, 08:21 AM
Looking to spend no more then 300 but of course only if there's a scanner out there with the option I want
Old 02-02-2013, 08:26 AM
Mein Auto: E39 528i
Thanks blue. I was wondering because the snapon guy loves to come around and take money if you will let him. I was told with my only 2 codes before my CEL is cleared that I need to look at the freeze frame etc. in order to figure out what is wrong. That is why the snapon/BMW deal seemed appealing. Though I am a little ignorant in this area to start with so...
-Tony
Old 02-02-2013, 08:29 AM
HTK12 HTK12 is offline
Mein Auto: E39 540i
Just get INPA and be done with it. Beats any under $500 diagnostic tool hands down. The cable for it costs $20-60.
Old 02-02-2013, 08:33 AM
bluebee's Avatar
The link for getting INPA and the cables is in this thread:
- Making sense of the most often recommended BMW diagnostic tools & cable interfaces (1)
NOTE: Let us know what cables you get so we all benefit from your effort.
Old 02-02-2013, 08:42 AM
Mein Auto: E39 540i
I can't seem to type anymore.
Bluebee you might want to update the guide for buying the cable. One can get BMW INPA EDIABAS K+DCAN USB Interface for $20-30 shipped on ebay. The guide claims that cable costs $120..
Old 02-02-2013, 10:02 AM
Dackelone Dackelone is online now
Mein Auto: 535i v8
Has anyone used this? For under $25 I don't think you can beat this deal!
Mini ELM327 OBDII OBD-II OBD2 Interface Bluetooth V1.5 Car Auto Diagnostic Scanner
http://www.amazon.com/ELM327-Interfa...nostic+Scanner
Its a OBDII port plug that works via blue-tooth with a smart phone. Then you will need the torque app for $4. It would be a very cheap way to read OBDII codes. I have ordered it and will try it with my euro 535i V8 e39.
Here is a guy who used it on his bmw 135i...
http://www.1addicts.com/forums/showthread.php?t=789400
Old 02-02-2013, 10:12 AM
Mein Auto: E39 540i
ELM interfaces are pretty useless on e39. You can't access SRS (airbag), ABS etc. Buy INPA cable, the software is free. Considering you can get it for $20-30 I wouldn't bother with ELM.
Old 02-02-2013, 10:38 AM
Looks like the INPA cable software CD would be best. The only bad is that I don't have a laptop only a desktop house computer
Old 02-02-2013, 10:42 AM
Mein Auto: 535i v8
I have a hand held OBDII scanner. This is what I use...
http://www.amazon.com/Actron-CP9580A...9830440&sr=1-4
I am sure you could also use a cheap-er one as long as it has CAN/BUS for ABS and airbags. I bought this scanner before knowing about the INPA cable.
Old 02-02-2013, 10:45 AM
Dack: how does that tool work for you and what modules and codes can you retrieve with it
Old 02-02-2013, 10:48 AM
Mein Auto: 535i v8
I have only used it to read my DME. I was able to see that my MAF and O2 sensors were shot. I picked it up when it was on sale for $150. I was in the same boat... I did not have an etra pc to use with a cable,
For my 135i I have the Bav-Tech cable, but it woud not work right on my EU spec e39 since my 135i is a US spec car.
I am curious to see how that Torque app works with the blue tooth reader. That should arrive here next week. I will update this thread that.
Dack
Old 02-02-2013, 10:51 AM
Dack thank you let me know how it works
Old 02-02-2013, 10:58 AM
Have anyone tried the bmw C110 scan tool: http://www.ecutool.com/C100-2-OBD2EO...C110_9202.html
Old 02-02-2013, 11:31 AM
Mein Auto: E39 540i
I would rather buy a used laptop + INPA cable before any handheld scanner like those mentioned in this thread. One can find working laptops for $50+. Neither one of those mentioned can code new modules/update he software in them, but with INPA cable you can. Example: I had to replace the Airbag control module in my e39, because it failed (internal error 240). Bought used one for $60, installed it and coded with NCS Expert (same cable as INPA). Dealer has quoted people $1000+ for replacing the airbag control module. With the cable you can do anything the dealer can..
While INPA might not the best out there, it's the best bang for buck solution by far. Autologic would be more user friendly, but considering $10 000+ price tag it isin't for the DIY guy..
Old 02-02-2013, 12:59 PM
bluebee's Avatar
Let's find one or three to quote for the team, so others can test it out for us.
I need a cable myself - but I only have Linux. Sigh.
Old 02-02-2013, 01:04 PM
Mein Auto: E39 528i
Is this only a windows product? I have a few Mac's, but no PC's.
-Tony
Old 02-02-2013, 01:35 PM
Mein Auto: E39 540i
Here's few Ebay sellers for the BMW INPA K+D-CAN cable:
First $24
Second $26
Third $26
If one doesn't want to buy from ebay for what ever reason DealExtreme sells it too here $37
Since you got linux how this is an issue? Because you got linux I assume you got some experience with computers? Just virtualize windows xp. Some distributions have virtualization tools pre-installed.
Sigh. Mac is a PC, if it ain't an ancient one. All 2007 mac's are PC's inside the fancy case. Use bootcamp or virtualize windows. And yes only windows.
Last edited by HTK12; 02-02-2013 at 01:41 PM. Reason: Added DealExtreme to sellers
