Old 02-02-2013, 01:05 AM
Kyungmo Oh Kyungmo Oh is offline
Mein Auto: 528i
Terminal Voltage Fault.
Hi~
I have a 2008my E60 528i (Korean ver., mileage: 50,000ml)
Sometimes my car sent a message like "Battery discharge is increased" via iDrive display, especially in cold weather.
(I translated the msg from Korean. So it can be a little different from US ver.)
So I changed my battery to new one (Bosch Silverlite DIN 80Ah 720CCA battery).
While changing the battery, I also checked a battery terminal voltage.
Unfortunately, the voltage was around 14.9-15.1V (ignition on). =_=
According to the E60 Service Manual (Bentley Publisher), normal voltage range is 13.8-14.5V.
Over 14.8V means that the generator is most likely to be faulty.
When I went to BMW Service Center to register new battery,
The mechanic said that "There was one stored over-voltage error and I erased the error by scanner tool"
After that, I replaced the generator(alternator) to re-manufactured one
from the BMW dealershop to new one.
But it doesn't solve the problem.
Re-programming the DME doesn't help, too.
I checked the voltage at the positive terminal under the hood AND the battery terminal.
Both results were the same as 14.8-15.1V.
It is also the same result as before the replacement.
What do you recommend to make it right?
It is possible that the re-manufactured voltage regulator is also faulty.
How can I check the voltage regulator is working properly?
Old 02-02-2013, 07:14 PM
H F H F is offline
Mein Auto: 2005 545i
Originally Posted by Kyungmo Oh View Post
Hi~
Try changing the charging relay in the trunk fuse panel...its possible that its not shutting down the alternator wen it hits 14 .5 volts and keeps charging the battery .....its a black 1inch x 1 inch square with a diagnal little handle.. its the biggest fuse , u cant miss it . only 25 bucks,,,, worth a try hope it works for u...
Old 02-05-2013, 05:50 AM
Mein Auto: 528i
Thank you all!!!
regulator, voltage
