E46 (1999 - 2006)
Old 02-02-2013, 10:01 AM
jimduke jimduke is offline
Mein Auto: 325ci
Musty smell from air vents
2001 325 Ci.
When I first start the motor a musty smell comes from the air vents.
I bought a spray for this from BavAuto. The instructions say to spray it into the air intake vent and it will recirculate in the condensor and kill the fungus build-up.
Where is the air intake? Perhaps the cabin air filter section under the hood near the windshield? Any fear of wetting electrical circuits?
Old 02-02-2013, 10:24 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
Which product did you buy? Most of these products, such as Einszett Klima-Cleaner, are intended to be sprayed deep into the center vent via a long tube. The idea is to deliver the foam to the A/C evaporator housing, which is where the stink originates.
After the treatment is complete, try shutting off the A/C and running fresh outside air through the vents for a few minutes before you reach your destination. Doing so helps to dry out the system and reduce the growth of the stinky microorganisms.
Old 02-02-2013, 07:27 PM
TannerT TannerT is online now
Mein Auto: 03 330ci 3pdl 81 CB750
Also check filter housing you never know what you will find lol.
Sent from my PantechP9060 using Bimmer App
sFormula SAE "Speed is Sexy"
Old 02-03-2013, 05:23 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by G. P. Burdell View Post
The idea is to deliver the foam to the A/C evaporator housing, which is where the stink originates....
If it helps, we've covered the gym sock odor from the A/C in gory detail over here:
- How to UNDERSTAND and then RECTIFY the BMW stinky gym sock AC odors (1) (2) (3) (4)
Here's just one post, by way of detail:
Originally Posted by bluebee View Post
With the summer in full swing, the AC stink problem arises again.
With another year under our belts, is this the recommended set of ac-stink problem statements and recommended solutions?
STINKY AC PROBLEM:
- It's first, and foremost, a BMW A/C downsize design problem (too cramped for proper ventilation of evaporator coils)
- The design problem allows food (dust), water (evaporator coils & ducts) and microbes (stinky poo) to coexist
- Resolution entails design, maintenance, & behavioral modifications (reduce the water, food, and stinky microbes)
DESIGN MODIFICATIONS: (Note: These are draconian)
- Cut hole in driver right-foot panel so you can spray germicide directly on evaporator coils (kill the stinky microbes)
- Drill a larger hole &
clean the evaporator fins with a toothbrush (less food for the stinky microbes)
Unkink the E39 evaporator duct (behind dash) by wiring the damper (less water for the stinky microbes)
MAINTENANCE MODIFICATIONS: (Note: These are judicious)
0. Reseat the two cabin-air micro-filters in the engine bay (BMW says stink can get in if they're not seated well)
1. Check if there is water normally draining from under the car after running your AC on a hot day
If there's no water pooling on both sides of your parking spot ... then ...
2. Clear the two undercarriage drain tubes any way you can:
- Some people suggest you snake a coat hanger past the multiple elbows to the evaporator coils to unclog
- Probably more reliable is to attach 13.5mm to 14.0mm OD plastic tube to both drain hoses & blow out obstructions
3. Unclog the drain holes & tubes in the two engine bay micro filters
- Some suggest snaking a six-inch length of coat hanger into the holes from the cabin filter downward thru the rubber drain hose
And, for more serious cases of BMW stinky AC:
4. Replace both engine-bay cabin "micro" filters (less food for the stinky microbes)
If eliminating water has been done, yet the stinky-AC microbes are still active ...
5. Spray tons of disinfectant in the air intake or directly onto the evaporator (through the drilled hole method).
- You'll need tons of germicide because it's not a direct shot to the evaporator coils from the air intakes
- Or try somehow to spray germicide upward hopefully onto evaporator coils from the undercarriage drain tubes
- While you're at it, spray ample germicide in central cabin vents (hoping some germicide lands on evaporator coils)
Note: The undercarriage drain tubes are apparently hard to remove for direct access to the evaporator coils; and, worse yet, they have a 90-degree elbow and 1-foot horizontal run, so, they're difficult to get a coat hanger into and even more difficult to get germicide up far enough to coat the evaporator coils.
BEHAVIORAL MODIFICATIONS: (Note: The fact we have to do this is ludicrous)
- Each trip, turn the AC off five miles before you arrive at your destination (less water for the stinky microbes)
- Park slightly nose upslope presumably so horizontal drain tubes drain better (less water for stinky microbes)
- Once a day, turn the heat up to 90 degrees and cook for 15 minutes (kill the stinky microbes)
- Set the AC to 72 degrees, "Auto", "Snowflake", & "
Circle without the A" (basic setup but doesn't help much)
Note: Yes, it's crazy to own a "luxury BMW" and then have to babysit the AC by turning it off or turning the heat up to 90 degrees in the hot summer so that it doesn't embarrass you with AC stink when you have a customer in the car; but, what else can you do?
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
