Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 02-02-2013, 10:40 AM
Stonehenge Stonehenge is offline
Mein Auto: 2004 BMW 325ci
2004 325ci EML problem
Hello, I have a 04 BMW 325ci. My EML light came on and the car wouldnt start. I found the rubber ends dry trotted from thethe vacuum F to the fuel filter. Also found the intake manifold runner valve broken. Replaced /fixed both problems and it ran wonderfully for two days. I got in the car to find it wouldnt start again and the EML light back in. Connector at the F had came off. I reconnected it and still wont start. Any idea what the problem can be?
Old 02-17-2013, 10:08 AM
Thanks for the overwhelming amount of help guys. :P
I figured it out.
Old 06-05-2013, 11:22 AM
DiverDave714 DiverDave714 is offline
Mein Auto: 2004 325i
I just encountered this problem with my 2004 325i. I have plenty of battery power and I had just driven to the store, but now the EML is on and when nothing happens when trying to start. What did you end up finding was your problem? Please...
