E46 (1999 - 2006)
Old 02-02-2013, 12:47 PM
Jsmk23 Jsmk23 is offline
Mein Auto: 02 BMW 325i
Weird noise coming from engine.
I have a question for you guys. There's a whistling/rubbing noise coming from engine when I start it up. The noise gets louder as I accelerate but goes away after 5-10 of driving.
It usually does this from a cold start up.
Also, I tried to listen if it's coming from the pulleys but it sounds like it's coming from more in the middle of the engine.
Old 02-03-2013, 05:04 AM
allancharlton allancharlton is offline
Mein Auto: 2003 3 series convertable
that is almost the same problem i have. but more of a rattle and now i am getting a misfire at low revs.....are you having any other problems?
Old 02-03-2013, 10:32 AM
No nothing else besides the noise.
Old 02-03-2013, 03:59 PM
01e46sprt 01e46sprt is offline
Mein Auto: 2001 Bmw 325ci sport
I have The same issue on my 01 325. It's your secondary air pump. It runs only when the car is cold to warm the cats. Only runs for about 5 mins than goes away. What's happening is it's become dirty after so long and that's what causes the noise. It's not a big deal if you can deal with the whistle for 5 mins every morning. Atleast that's what my mechanic told lol.
Old 02-03-2013, 09:36 PM
Did you ever change it? And would you know if it's hard to do?
Old 02-03-2013, 09:41 PM
No I didn't change it because i heard the part alone is like $600. On the other hand today I got a SES light and code p0171 is what came up when I scanned it. Do you have a SES light on ? The reason I'm asking is because it may not be the secondary air pump it could be a torn intake hose (vacuum leak) if that's the case the part is well under $100. Lmk ASAP.
Old 02-03-2013, 09:43 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
No need to change anything....that`s just the way it`s *supposed* to function....
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 02-03-2013, 09:46 PM
I can still slightly hear mine after the car is at proper running temp. Also the p0171 code is leading me to believe that there's a tear in that boot/hose which is causing the whistle and running to lean ??? May also be jsmk's problem as well
Old 02-03-2013, 10:52 PM
Wow lol it's funny you say that because the SES actually came on earlier today on my way home.
Old 02-03-2013, 10:54 PM
Have someone scan it and find out what the code is. If its p0171 we both have same issue. Also how long has the noise been there ?
Old 02-03-2013, 11:33 PM
I had the car about a month. And it's been making that noise about 3 weeks now. It's starts on a cold startup and gets loud as I accelerate and goes away 5 mins.
Old 02-03-2013, 11:36 PM
Ya sounds like same issue as mine. Lmk what that code is ASAP.
Old 02-03-2013, 11:38 PM
Will do, Thanks.
Do you happen to know what your code means?
Old 02-03-2013, 11:53 PM
Well it says system is too lean which means there's more air than fuel mixing which means there's a vacuum leak somewhere. Hopefully it's leaking from the intake boot. Have it swapped out and problem solved.
Old 02-04-2013, 12:20 AM
When do you plan on changing yours?
On e46 fanatics, ppl are telling me it's the pulleys/tensioners
Old 02-04-2013, 07:01 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
The SAP doesn't get louder as you accelerate. It actually gets drowned out by other sounds. So the possible good news is, investigate for a vacuum leak. If its just a torn or loose boot, it's a lot cheaper than replacing the pump.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 02-04-2013, 11:26 AM
Thanks bro. Glad to hear that.
Old 02-05-2013, 02:39 PM
Just went to pepboys to get the codes because autozone couldn't do it.
And I got 2 codes.
P0430 & P0444
Old 02-05-2013, 03:02 PM
Check these 2 threads. Both from this forum. Should answer your questions.
http://forums.bimmerforums.com/forum...d.php?t=917830
http://www.bimmerfest.com/forums/sho...d.php?t=391106
Old 02-05-2013, 03:52 PM
Thanks man, idk where to start. Now idk if the pulleys is what's making the noise.
Old 02-05-2013, 04:05 PM
It may sound crazy but have someone check the alternator. If the bearings inside go bad they'll make the noise you posted in the video. Btw I just noticed there was a video and watched it and your noise is much different than mine. You have more of a metal to metal type jingling noise for lack of better words. Could very well be an alternator on its way out. Just seen the pic to looks like a really nice clean car.
Old 02-05-2013, 04:10 PM
Yeah I know I am confused lol Others say pulleys and others say intake boot. Now with these codes it could mean also a whole other thing.
Thanks bro. You have a pic of yours?
Old 02-05-2013, 04:16 PM
No problem man I hope you figure it all out and everything goes well for you.
I don't have a pic yet. Everytiime I wanna get her cleaned up and snap some pics it starts to snow lol. (NJ). Ill post some up real soon.
Old 02-05-2013, 04:21 PM
Thanks I hope so.
For sure bro, can't wait to see some.
Old 02-05-2013, 05:10 PM
Idk if this helps, but after I shut off the engine it makes this air noise.
Here's how it sounds
